Distributor Question
Old Nov 17, 2007 | 09:56 AM
beseman's Avatar
Default Distributor Question
when i replaced my dizzy last fall i used a dizzy from a b16 on my ls, i had to cut the wires to put a new plug on and everything. now i think i have a problem with my dizzy again, so my question is, if i have to replace the rotor (or any other internal part of the distr.) do i need to get parts for the specific b16 that the old dizzy came off of or are all parts interchangeable in the diz?
Old Nov 17, 2007 | 12:20 PM
GRAF-FITI's Avatar
* B A N N E D *
Default Re: Distributor Question (beseman)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by beseman &raquo;</TD></TR><TR><TD CLASS="quote">when i replaced my dizzy last fall i used a dizzy from a b16 on my ls, i had to cut the wires to put a new plug on and everything. now i think i have a problem with my dizzy again, so my question is, if i have to replace the rotor (or any other internal part of the distr.) do i need to get parts for the specific b16 that the old dizzy came off of or are all parts interchangeable in the diz?</TD></TR></TABLE>
is it that hard to type the word distributor instead of using the word "dizzy" 4 times then abbreviate that with the word "diz"???????
to answer your qustion, you should be fine....go with ones from a 95 del sol b16 vtec if you want to be extra sure
spooncivic01
Feb 3, 2008 05:30 PM
EG_LS
Nov 19, 2007 03:04 PM
Lo-Buck EF
Jun 30, 2005 02:27 AM
JHD_DA
Jul 1, 2004 07:03 PM
