OBD2 to 1 conversion TDC Code???!! need answeres ASAP!
obd2 ls/vtec integra converted to obd1 on a chipped p28 throws TDC code and runs like ***
put back to stock ecu runs fine.
any ideas. Ive checked, double checked wiring of the conversion harness and the timing. AND used to different chipped ecus both from running customer cars.
let me know
thanks
let me know
thanks
That'sa due to the crank angle sensor. On OBD2 cars, it's down by the crank pulley. On OBD1 car's, it's in the dizzy.
sooo.... since it is an ob1 ecu and obd2/obd1 dist are the same... shouldnt it not matter? at least the jumper harness has it going nowhere
sikcrx80
May 1, 2023 05:16 PM
stevieteg
May 17, 2004 11:35 AM
