header installation
Old Nov 14, 2007 | 10:01 AM
chris3k's Avatar
Default header installation
sooo due to my dc headers not having a eo number, i have to install the stock one again. I have gone through this process before but i had help, this time around im doing this solo. is there a write up, or if somebody could give me a step by step walk through. i know this is simple but i do not want to mess up. any help will be appreciated!
-chris
Old Nov 14, 2007 | 10:28 AM
0hboitony's Avatar
Default Re: header installation (chris3k)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by chris3k &raquo;</TD></TR><TR><TD CLASS="quote">sooo due to my dc headers not having a eo number, i have to install the stock one again. I have gone through this process before but i had help, this time around im doing this solo. is there a write up, or if somebody could give me a step by step walk through. i know this is simple but i do not want to mess up. any help will be appreciated!
-chris</TD></TR></TABLE>
Really... Its just a few bolts and out it goes! Take of the from the head, than take out the bolts thats connect to CC, pull the o2 sensor harness to disconnect it, and drop it out. If you have bolts that is connect to the back of the block... Theres like 2-3 bolts to take out. Easy easy easy....
Old Nov 14, 2007 | 10:30 AM
12KRPM's Avatar
Default Re: header installation (0hboitony)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 0hboitony &raquo;</TD></TR><TR><TD CLASS="quote">
Really... Its just a few bolts and out it goes! Take of the from the head, than take out the bolts thats connect to CC, pull the o2 sensor harness to disconnect it, and drop it out. If you have bolts that is connect to the back of the block... Theres like 2-3 bolts to take out. Easy easy easy....</TD></TR></TABLE>
Yupz... The only issue you might run into when removing your header is clearance with your radiator. If you run into that issue, post back..
Old Nov 14, 2007 | 11:13 AM
chris3k's Avatar
alright thanks, if i have problems i will post
Old Nov 14, 2007 | 12:25 PM
Padawan's Avatar
Darth ModerVader
What DC header were you running that didn't have a CARB number? JDM 4-1?
Old Nov 14, 2007 | 01:09 PM
myfirstdc2's Avatar
Default Re: header installation (Padawan)
most likely cuz i have a jdm dc 4-1 as well and no carb number. but the regular verion has the carb numbers.
Old Nov 15, 2007 | 01:08 PM
chris3k's Avatar
they are the 4-2-1 ceramic coated. they are supposed to be c.a.r.b exempt but there is no plate welded on with the eo number. i hope they are legit, i got them off of cardomain
Old Nov 15, 2007 | 01:39 PM
lmike6453's Avatar
don't forget to disconnect o2 sensor first!!!!!
5200BB6
Jun 21, 2005 01:46 PM
mrdanglez
12
May 15, 2004 07:13 PM
xplanetearth420x
Mar 12, 2004 03:34 AM
confucius
Apr 29, 2003 04:16 PM
CR-V
May 7, 2002 09:33 PM
