93 integra
Old Nov 17, 2007 | 07:22 AM
WEEZY034's Avatar
Default 93 integra
i have a 93 teg... I have a ebiach lowering springs.. and kyb shocks.. when i go 60 my wheel start to shake.... i need help plz..... and where can i find a good sway bar from... thanks.....
Old Nov 17, 2007 | 07:25 AM
Dogginator's Avatar
Daisy... Daisy...
Default Re: 93 integra (WEEZY034)
Have you checked your tire balance? Bad axles can cause this as well. Does the shake reduce if you go faster or slower?
Old Nov 17, 2007 | 07:30 AM
WEEZY034's Avatar
Default Re: 93 integra (Dogginator)
when i go slower... it dont shake no more
Old Nov 17, 2007 | 07:36 AM
Dogginator's Avatar
Daisy... Daisy...
What about at say 70 MPH or is the shaking at 60 so severe that you must slow down?
Old Nov 17, 2007 | 07:39 AM
WEEZY034's Avatar
the faster i go the wrost the wheel shake..... when i hit 70.. it is shaking very fast so i have 2 slow down....
Old Nov 17, 2007 | 07:48 AM
Dogginator's Avatar
Daisy... Daisy...
Are you lugs tight? Are your wheels straight (not bent)? A sway bar should not cause shake like you are experiencing.
Old Nov 17, 2007 | 08:44 AM
WEEZY034's Avatar
i am asking for a god type of sway bar for my car... i dont own 1
Old Nov 17, 2007 | 08:53 AM
Dogginator's Avatar
Daisy... Daisy...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by WEEZY034 &raquo;</TD></TR><TR><TD CLASS="quote">i am asking for a god type of sway bar for my car... i dont own 1</TD></TR></TABLE>
Post that is the MarketPlace not here.
Like I said, a sway bar is not going to fix your problem. Does the vibration stay the same with the clutch engaged or disengaged at 60MPH?
Old Nov 17, 2007 | 12:16 PM
WEEZY034's Avatar
i have a auto....
Old Nov 17, 2007 | 12:23 PM
GRAF-FITI's Avatar
* B A N N E D *
get your tires balanced
Old Nov 17, 2007 | 01:52 PM
EK 2 9K's Avatar
Default Re: 93 integra (GRAF-FITI)
^^yes
Old Nov 17, 2007 | 01:57 PM
PhoenixDownVII's Avatar
Default Re: 93 integra (EK 2 9K)
Wow. Does anyone speak/type in english on this forum?
Old Nov 17, 2007 | 02:50 PM
Fook_me_honda's Avatar
Default Re: 93 integra (PhoenixDownVII)
bad ball joints maybe? or loose tie rod?
Old Nov 17, 2007 | 04:08 PM
b0yJeEnYuS's Avatar
yea i had that on my 90 integra and my tires werent balanced. i balanced them at work the next day and she rides like a dream
Old Nov 17, 2007 | 10:04 PM
Kirk GS-R's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by GRAF-FITI &raquo;</TD></TR><TR><TD CLASS="quote">get your tires balanced</TD></TR></TABLE> x2
Old Nov 17, 2007 | 11:30 PM
denraweb's Avatar
Default Re: 93 integra (Kirk GS-R)
Not the tires. If they were out of balance, it wouldn't be consistent...it would go away and then come back at certain speeds. Usually stops after about 60-70mph.
Old Nov 18, 2007 | 01:22 AM
EFLS89's Avatar
just get a whole alignment and tire balance. and if something is really wrong still, then maybe your axel is bad, or something else.
Old Nov 18, 2007 | 11:07 AM
Jackson123's Avatar
Default Re: 93 integra (EFLS89)
if its a 93, and you havent changed/replaced your cv joints, that could be your problem, had same problem on my 94 with 180k on it, and fixed problem, if you dont change them, your wheel could straight fall off on the highway
Old Nov 18, 2007 | 11:11 AM
blessedrican's Avatar
it is true what he saod
Old Nov 18, 2007 | 12:07 PM
WEEZY034's Avatar
Default Re: 93 integra (blessedrican)
so should i get my cv joints don or the wheel balance/ alignment... plz help
Old Nov 18, 2007 | 06:58 PM
Dogginator's Avatar
Daisy... Daisy...
Check the wheel balance first and move on from there.
Old Nov 18, 2007 | 07:02 PM
roycivic92's Avatar
start from the cheapest fix to the expensive. maybe a wheel balance will fix it.
Old Nov 20, 2007 | 08:15 AM
MASTER4666's Avatar
Default Re: 93 integra (roycivic92)
Wheel balance
You may have lost a wheel weight.
Old Nov 20, 2007 | 10:20 AM
Uncle Ben's's Avatar
Cogent Argument Enthusiast
Default Re: 93 integra (Jackson123)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Jackson123 &raquo;</TD></TR><TR><TD CLASS="quote">if its a 93, and you havent changed/replaced your cv joints, that could be your problem, had same problem on my 94 with 180k on it, and fixed problem, if you dont change them, your wheel could straight fall off on the highway </TD></TR></TABLE>
WTF are you talking about. I've had a CV joint fail on me; do you know what happened? Power wasn't transmitted to the wheels(it was the right one) and I had to have my car towed to a shop to have it replaced.
Old Nov 20, 2007 | 09:30 PM
LOE4DOE's Avatar
Default Re: 93 integra (Uncle Ben's)
make sure you tightend all the lugs and torqued them
