type R cams
Old Aug 29, 2008 | 05:55 AM
Dwizzy's Avatar
Default type R cams
k im doing a GSR swap to my 94 Ls n i was wondering how much of a difference will the Type R cams Springs and Retainers actually will make like hp wise n will they be able to handle boost
Old Aug 29, 2008 | 06:37 AM
dtme46's Avatar
Default Re: type R cams (Dwizzy)
ive used itr cams on a couple of turbo motors and it seemed to work great
Old Aug 29, 2008 | 09:48 AM
00GsR-TeG's Avatar
yea i would just go with the super tech valvetrain and the itr cams. The itr cams are very good all around cams na or turbo. I know the stock gsr's are fine for 500+
Old Aug 29, 2008 | 10:22 AM
racebum's Avatar
Default Re: type R cams (00GsR-TeG)
the dual stage manifold of the GSR will be a bottle neck in your setup. the ITR cams would really benefit from more intake and also a decent header. how much are you paying for the ITR cams and honda yellow springs anyway?
Old Aug 29, 2008 | 05:33 PM
Dogginator's Avatar
Daisy... Daisy...
GSR retainers = ITR retainers.
The differences are as follows:
ITR LMAs
ITR intake valves
ITR intake valve springs
ITR exhaust valve springs (ITR exhaust springs = GSR intake springs)
ITR camshafts
From the dyno plots that I have seen, untuned ITR cams in a stock GSR engine make about 11 whp additional.
Old Aug 29, 2008 | 09:50 PM
racebum's Avatar
Default Re: type R cams (Dogginator)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Dogginator &raquo;</TD></TR><TR><TD CLASS="quote">GSR retainers = ITR retainers.
ITR LMAs
ITR intake valves
ITR camshafts
From the dyno plots that I have seen, untuned ITR cams in a stock GSR engine make about 11 whp additional.</TD></TR></TABLE>
you know i learned this the hard way when i was doing the engine build. i ordered all new honda retainers for the yellow springs. low and behold it's the same thing as my stock GSR.
also, dog, did the car pick up 11whp with the stock gsr manifold? that would be a great gain if it was the case. i couldn't find any dyno charts besides that lame super street article where they tested a low compression motor and made no gains.
Old Aug 30, 2008 | 01:16 PM
Dogginator's Avatar
Daisy... Daisy...
Default Re: type R cams (idrivesideways)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by idrivesideways &raquo;</TD></TR><TR><TD CLASS="quote">also, dog, did the car pick up 11whp with the stock gsr manifold? that would be a great gain if it was the case. i couldn't find any dyno charts besides that lame super street article where they tested a low compression motor and made no gains. </TD></TR></TABLE>
The dyno that I saw was for a bone stock 94 GSR. No tuning was done. There was a major torque hole from 4400-4800 RPM because the VTEC switched too early for those cams.
AranLamb
Sep 21, 2012 05:19 AM
ilovemyh22
Feb 18, 2009 03:08 PM
imptricer
Apr 10, 2007 02:06 PM
H2nr
Mar 19, 2004 07:54 AM
hybrider
Jan 28, 2002 01:38 AM
