need advice
Old Aug 27, 2008 | 01:37 PM
dadrought6's Avatar
Default need advice
hey guys i own a 1993 ls integra. it has the original b18a1 with place racing mounts and an intake. my question is i noticed if I watch someone else driving my car, when you let out on the clutch the front right wheel vibrates back and forth. its not a hydro tranny so i did not know if this was normal for cars with cable trannys or if this "issue" was related to the type of transmission or was caused by other things (I know place racing mounts are old as dirt so could that be the cause?). any advice would be great.
Old Sep 3, 2008 | 12:33 PM
dadrought6's Avatar
anyone?
Old Sep 3, 2008 | 01:26 PM
Dogginator's Avatar
Daisy... Daisy...
Default Re: need advice (dadrought6)
Is the wheel bent?
Are the lugs tight?
Have you checked the tie-rods?
Have you checked the ball joints?
Have you checked the bushings?
Old Sep 8, 2008 | 06:58 AM
dadrought6's Avatar
the wheels are not bent, the lugs are all tight as well. It only does it when you take off from a stop. I have not yet checked the other things you mentioned but i will be sure o do that and let yall know what happens. thanks
superbangkok
14
Sep 19, 2006 08:17 AM
chattownrexer
Jun 6, 2004 09:07 AM
93slmdcvcsi
Feb 1, 2004 11:09 AM
Flexmyrex
Nov 27, 2002 09:20 PM
