Even more problems with the teg....
Old Aug 23, 2008 | 04:41 PM
bob_long737's Avatar
Default Even more problems with the teg....
Ok so I have a 91 GS and occasionally its will not start. It turns over and everything but doesnt start. So if I just let it sit for a little (about a min) it will usually start. But when it does quite a bit of white smoke comes out...then it runs perfect without smoking or anything once its started. Whats the deal? bad seals? fuel pump on the fritz? help me out guys im about to put a new clutch in and dont really need more probelms.
Old Aug 23, 2008 | 04:53 PM
Bignel00's Avatar
Default Re: Even more problems with the teg.... (bob_long737)
start out with your basic test man. do a compression test. check your distrubtor. plugs, wires. make sure your fuel pump is coming on .check your fuses i could goo on for hours . Search it up its really the best way to learn .
Old Aug 24, 2008 | 04:12 PM
Default Re: Even more problems with the teg.... (Bignel00)
I was just wandering if anyone has had this same problem or not.
Old Aug 24, 2008 | 05:29 PM
dtme46's Avatar
isnt white smoke a blown headgasket
Old Aug 25, 2008 | 04:45 PM
Default Re: (dtme46)
could be... anyone know?
Bagged_em1
Oct 27, 2016 04:43 PM
turbo-crx
Oct 3, 2008 08:22 PM
Hondas_Only
Feb 7, 2008 07:44 PM
menappi
Sep 13, 2003 08:26 AM
SIK IN DA HED
Apr 25, 2003 06:16 AM
