Smog failed... HELP
Old Aug 28, 2008 | 12:46 PM
llozll's Avatar
Default Smog failed... HELP
i failed smog with ridiculous numbers
here's what report says:
15mph (rpm: 1817)
(MAX/MEASURED)
HC: 90/220 CO: .54/.78 NO: 711/2525
25mph (RPM: 2199)
(MAX/MEASURED)
HC: 56/72 CO: .53/.14 NO: 754/359
what should i do to solve this?
it also says this vehicle failed the ignition timing check due to engine rpm being out of tolerance. wtf do i do?
almost deadline now.. help me out guys!!
thanks,
OJ
Old Aug 28, 2008 | 01:03 PM
99Geeezer's Avatar
Default Re: Smog failed... HELP (llozll)
well first off check the timing and set it to specifications. then check for a vaccum leak. a vaccum leak can trick the map sensor to thinking the engine is under load and the extra air can lean to a lean condition. that where i would start.
lek9l
44
May 1, 2016 03:30 PM
the_tensl
Feb 19, 2015 10:26 AM
dumkopf
Aug 29, 2007 05:51 AM
alphaquake
15
Dec 31, 2002 04:18 PM
GSRaCeRbOI
Oct 23, 2002 12:18 PM
