clutch problems
Old Aug 28, 2008 | 02:43 PM
dc2_guy's Avatar
Default clutch problems
ok i just bought a 97 acura integra and for some reson when i press the clutch its week like i can press the clutch but no pressure at all it hits the floor there is no pressure at all even when i lift the pedal its really really soft there no werid noise that i can hear when driving or parked. thank you for helping
Old Aug 28, 2008 | 02:54 PM
neardon's Avatar
I'm a Jackass
Default Re: clutch problems (dc2_guy)
Sounds like you have some bubbles in your clutch lines. You're going to have to bleed them. Its fairly simple, just like brakes.
Old Aug 28, 2008 | 04:19 PM
intekragsr's Avatar
Default Re: clutch problems (neardon)
look under the clutch pedal, and see if there is fluid on the rod.
Old Aug 30, 2008 | 04:46 PM
dc2_guy's Avatar
Default Re: clutch problems (intekragsr)
if there is what does it mean
Old Aug 30, 2008 | 05:39 PM
roberts88's Avatar
if you bleed it and it still has no pressure you might need to replace the clutch master and slave.
Old Aug 30, 2008 | 06:16 PM
StayKrafty's Avatar
Just curious, did you drive this car before you bought it?
Old Aug 31, 2008 | 01:57 AM
dc2_guy's Avatar
yes i did the master looks new but the slave is all rusted u think it might be the slave
Modified by dc2_guy at 7:56 AM 8/31/2008
Old Aug 31, 2008 | 11:53 AM
roberts88's Avatar
have you tried to bleed the system yet? if that doesnt work. disconnect the line from the clutch master and have someone press the clutch and see how much fluid comes out if its just dripping you need a new master. if thats good and its flowing. change the slave.
Ek9b20v
12
Mar 31, 2013 01:21 PM
xxgriffonxx2
Transmission & Drivetrain
Apr 28, 2010 10:18 AM
LOC714
Sep 23, 2004 12:34 PM
KooK
Jul 11, 2002 03:28 AM
