vtec problem
Old Aug 26, 2008 | 06:05 AM
DarikDisease's Avatar
Default vtec problem
vtec problem
Ok i just bought a 95 integra with a gsr swap it has a chipped ecu but not tuned.whenever you get on it vtec is kicking in at like 4200 which should be 5200. but when i do hit vtec the rpms go all crazy and jumps from 4 to 8 or 9. what could cause that? its like vtec is not kickin in like it should could it be the chipped ecu?
Old Aug 26, 2008 | 06:21 AM
neardon's Avatar
I'm a Jackass
Default Re: vtec problem (DarikDisease)
your chipped ecu will cause vtec not to engage at the stock point. You need to be more descriptive like what is the "rpms going all crazy" is vtec not crossing over at the right point for you? is the engine not running right in higher rpms?
Old Aug 26, 2008 | 06:25 AM
Default Re: vtec problem (neardon)
its like when it hits vtec it wont take off it has to build up. and the rpms jump around.
Old Aug 26, 2008 | 01:12 PM
anybody
Old Aug 26, 2008 | 01:29 PM
neardon's Avatar
I'm a Jackass
Check cap, rotor, plugs, wires, fuel filter, vtec solinoid screen, oil level, and make sure your timing is set right.
CivicSi95
Honda Civic (2006 - 2015)
Nov 22, 2008 11:20 AM
DXDOHCVTEC
Jul 29, 2004 10:34 PM
South Bay Surfer
23
Jan 2, 2003 04:42 AM
crxkenny
Dec 21, 2002 08:10 AM
