ignition timing issue????
Old Aug 29, 2008 | 06:22 PM
1992blueGSR's Avatar
Default ignition timing issue????
ok so i just put an ls trans in m 92 gsr, its now having an idling issues, meaning.... that after it starts it seems like it has no power, so i have to go WOT to get it out of a bog, under 3k it has no power, sometimes when it starts it barely idles, like about 200rpm, seems like the car wants to die but something wont let it, and sometimes the car idles t about 900, wich is were i have it set
now when you replace the trans there are a couple bolts bellow the dizzy, and i know the wrench i was using brushed against the wires on every turn of the wrench, is it possible that i could have knocked the car out of time? if so which way do i need to turn the dizzy to correct it
also once you get the car above 2.5k it feels fine, but once it drops below there is NO go
i have to slip the clutch out at 3k and at this rate ill need a new clutch in a month!!!!
Old Aug 29, 2008 | 08:44 PM
Default Re: ignition timing issue???? (1992blueGSR)
bump, come on!!!!!
Old Aug 29, 2008 | 10:37 PM
mr.beeks's Avatar
you said you brushed the wires so first thing ill be checking the connections.
check your negatives are they all connected?
Old Aug 30, 2008 | 04:06 PM
Default Re: ignition timing issue???? (mr.beeks)
thanks for the imput, all the wires were good, i was a vacuum line i missed
Old Aug 31, 2008 | 08:06 AM
swgateg's Avatar
its always something simple, good to hear its fixed
jdmacuraITR
Aug 17, 2014 09:42 AM
h-duced
Mar 12, 2009 01:45 PM
crxjarred
Feb 27, 2009 10:31 PM
aquabob89
Apr 25, 2006 10:02 AM
CrX-To-Tha-Max-v2.0
Mar 2, 2005 12:01 PM
