Quick Help for a Friend!
Old Aug 27, 2008 | 03:54 PM
XSIintegra's Avatar
Default Quick Help for a Friend!
This is where I plumbed the water lines
Old Aug 27, 2008 | 05:24 PM
SIRDelsol's Avatar
Default Re: Quick Help for a Friend! (XSIintegra)
dang man the gsr doesnt have the extra nipple and that other coolant line goes back into the head. i need some help!
Old Aug 27, 2008 | 05:25 PM
Dogginator's Avatar
Daisy... Daisy...
What is the question?
Old Aug 27, 2008 | 05:33 PM
SIRDelsol's Avatar
Default Re: Quick Help for a Friend! (Dogginator)
i have an 2.0 ls vtec set up and just put in a new gt3082r ballbearing turbo and ran the coolant lines. ran them the same way my friend ran his with no problems by "t"ing off the heater line hoses and adding my lines there.....yeah great until the coolant isnt staying in the lines and just steaming out as if the brass is melting or just not holding the coolant. i need them run different i think please help!!
Old Aug 27, 2008 | 05:35 PM
XSIintegra's Avatar
Default Re: Quick Help for a Friend! (SIRDelsol)
I was thinking about what you had said. I think its steaming because the water isn't moving threw the lines at all.
There should be heating lines available that are setup to warm the throttle body. You could probably use those instead.
Old Aug 27, 2008 | 05:38 PM
SIRDelsol's Avatar
hmm.... that could work..... does it matter how big the lines are?
Old Aug 27, 2008 | 05:56 PM
XSIintegra's Avatar
I believe whatever size line you have to use will be big enough. You'd have to do a lot of work to fit that turbo with a line that I would consider too small. There are people out there that will tell you that you don't have to water cool that turbo anyways. I personally like the idea of keeping her nice and cool though.
Old Aug 27, 2008 | 05:57 PM
SIRDelsol's Avatar
yeah same here well let me get to her tonight and ill let u know tmrw wats up.
Old Aug 27, 2008 | 06:03 PM
XSIintegra's Avatar
Sounds good. Your welcome to call or txt whenever. Send me a couple pix if you get a chance. I want to see your setup
Justin
Bobbyt5408
Nov 20, 2008 07:06 AM
Mr HYDE
Oct 2, 2006 06:07 AM
high boosted rex
Aug 24, 2006 07:03 AM
done
Oct 14, 2005 12:24 PM
adictionbass
Jan 18, 2005 01:53 PM
