car won start.
Old Aug 29, 2008 | 10:43 AM
jasko97's Avatar
Default car won start.
ok i got a 95 gsr that just died when mom mom was driving it. brought it to my house to check it out and it would crank but not turn over. when it died it was on the e line for gas. so put 5 gallons in and still wouldnt start. turned the key over and fuel pump turns on. so then i check for spark. no spark. replaced the spark plugs( under neath the old one smelt of gas). replaced the dizzy to see if the icm was the problem( had an extra one laying around). ok now i got spark. but now when i try to crank it , it is just a high pitch cranking noise now. any thoughts or things to check? oh yea timing belt, battary, alternator, and starter is good, but i didnt check the timing. PLEASE HELP
Old Aug 29, 2008 | 04:58 PM
jonni2000's Avatar
Default Re: car won start. (jasko97)
did you try the injectors?
Old Aug 29, 2008 | 07:08 PM
jasko97's Avatar
Default Re: car won start. (jonni2000)
yea it is getting fuel
Old Aug 29, 2008 | 08:10 PM
gsilnc's Avatar
check your main relay, might need a minor tack.
Old Aug 29, 2008 | 08:15 PM
gsilnc's Avatar
and your fuses also
Old Aug 29, 2008 | 08:32 PM
PaulMc's Avatar
Painfully Stupid
Default Re: (gsilnc)
Your main relay controls your fuel pump, so if you hear it prime you know that isn't the problem. Double check the rotor in the distributer, most of the time this problem turns out to be the distributer failing in one way or another. Check the harness wires that attach to the distributer. Another thing you can check is your fuse box, make sure every fuse under the hood and under the dash is intact.
Old Aug 29, 2008 | 11:16 PM
jasko97's Avatar
Default Re: (-PaulMc-)
yea everything is intacted got spark, bat is 12.55 volts, im just lost and frustrated
Old Aug 29, 2008 | 11:58 PM
wunfstgsr's Avatar
Loved
Community Favorite
Default Re: (jasko97)
You sure your mom diddnt miss shift and bend a valve! and not know she did or is she familiar with your car?
Old Aug 30, 2008 | 12:12 PM
PaulMc's Avatar
Painfully Stupid
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jasko97 &raquo;</TD></TR><TR><TD CLASS="quote">yea everything is intacted got spark, bat is 12.55 volts, im just lost and frustrated </TD></TR></TABLE>
You can spend all your time standing infront of your hood throwing darts and not hitting the target, I went through this about 4 months with my last integra, turned out buying a BRAND NEW distributer from Advance was a mistake because they forgot to put a rotor in it.
Make sure you have spark, fuel, and compression before you go digging any deeper trying to figure out why it's not starting.
Old Aug 30, 2008 | 03:35 PM
99JdmDc2's Avatar
usually its your distributor, when you have no spark with honda's from my experience.
Old Aug 30, 2008 | 06:14 PM
jasko97's Avatar
Default Re: (99JdmDc2)
i replaced the dizzy and i have good spark now
Old Aug 30, 2008 | 06:19 PM
StayKrafty's Avatar
You've checked the timing belt right? Maybe it skipped timing.
Old Aug 31, 2008 | 04:29 PM
jonni2000's Avatar
i guess you should try every possibility, from fuel, electric, timmimg, compression everything.....
Old Sep 1, 2008 | 07:36 AM
PaulMc's Avatar
Painfully Stupid
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jonni2000 &raquo;</TD></TR><TR><TD CLASS="quote">i guess you should try every possibility, from fuel, electric, timmimg, compression everything.....</TD></TR></TABLE>
Check your grounds, AND ALL fuses.
plantmylotus
10
Oct 14, 2008 10:49 AM
EJ1 LS guy
Jul 20, 2008 06:20 PM
blackep925
Apr 12, 2008 04:59 PM
StraightCivic
11
May 9, 2006 09:38 PM
turbocivic0618
Nov 24, 2005 08:20 AM
