Oil Light Blinking
Old Sep 3, 2008 | 06:32 AM
aemintgsr's Avatar
Default Oil Light Blinking
I have a 95 LS and i recently swaped back my stock engine (for the ref) and the oil light came on when i made a quick turn at a stop. i drove it home, turn it off, and turn it back on and there was no more light?! I open up the oil cap and i saw pressure going threw the head. My only guess could be that my oil pan is hella dented.
Old Sep 3, 2008 | 07:17 AM
aemintgsr's Avatar
anyone??
Old Sep 3, 2008 | 07:19 AM
LSracing94's Avatar
Default Re: (aemintgsr)
or your burning lots of oil....check the oil level with the dip stick..these motors will burn oil with their age
Old Sep 3, 2008 | 07:25 AM
aemintgsr's Avatar
Its a rebuilt and no blue smoke out the exhaust, but it is leaking oil threw the valve cover gasket
Old Sep 3, 2008 | 08:01 AM
PatrickGSR94's Avatar
Community Builder
Community Influencer
Active Streak: 60 Days
Default Re: (LSracing94)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by LSracing94 &raquo;</TD></TR><TR><TD CLASS="quote">or your burning lots of oil....check the oil level with the dip stick..these motors will burn oil with their age</TD></TR></TABLE>
haha my stock GS-R engine has 270K miles on it all original internals and doesn't not burn any oil.
OP are you saying your oil pan is dented, or are you just wondering if it's dented? Oil light flashing means there's not enough oil pressure. If the pan is dented, the oil pickup could be damaged or it's just not getting enough oil. If there is an oil leak and the oil level is low, then the pickup can get starved when going around a corner. If that happens for too long, you'll be looking at spun bearings or worse.
Old Sep 3, 2008 | 08:07 AM
LSracing94's Avatar
Default Re: (PatrickGSR94)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PatrickGSR94 &raquo;</TD></TR><TR><TD CLASS="quote">
OP are you saying your oil pan is dented, or are you just wondering if it's dented? Oil light flashing means there's not enough oil pressure. If the pan is dented, the oil pickup could be damaged or it's just not getting enough oil. If there is an oil leak and the oil level is low, then the pickup can get starved when going around a corner. If that happens for too long, you'll be looking at spun bearings or worse.</TD></TR></TABLE>
welp u got a healthy engine..rare to find that in integras lately
Old Sep 3, 2008 | 08:17 AM
aemintgsr's Avatar
it is dented, im saying this cuz i here when the oil pan is dented vtec wont kik in cuz of oil pressure so im wondering if thats the cause. (yeah i kno i dont have vtec)!
Old Sep 3, 2008 | 09:17 AM
Community Builder
umm yeah that's probably the reason. You need to drop that oil pan and hope it hasn't damaged the oil pickup. Either way, get a new pan on there ASAP.
Old Sep 3, 2008 | 03:02 PM
aemintgsr's Avatar
I have a spare 90-93 oil pan from the B18a1, im sure there wouldnt be a problem or a difference?? right?
eric416
Nov 4, 2008 12:44 PM
mtownek9
Apr 1, 2008 01:54 PM
motormike40
Sep 19, 2006 12:47 PM
DC_RaceR
Feb 23, 2006 02:00 PM
Allstar
Oct 29, 2001 03:05 PM
