clutch question
Old Sep 3, 2008 | 12:19 PM
wastedyouth2542's Avatar
Default clutch question
is it possible to put your clutch disk in backwards and it still work or not?
Old Sep 3, 2008 | 12:24 PM
PatrickGSR94's Avatar
Community Builder
Community Influencer
Active Streak: 60 Days
Default Re: clutch question (wastedyouth2542)
No, I believe the center portion of the disk sticks out further on one side than on the other side. If you put it in backwards, you would not be able to bolt the pressure plate to the flywheel.
Old Sep 3, 2008 | 12:26 PM
Default Re: clutch question (PatrickGSR94)
ok, because my friend who works for toyota told me that it is possible to put it in backwards but under high loads it would hit the flywheel bolts. i was just curious it this was true or not. by the way its a 96 se
Old Sep 3, 2008 | 12:28 PM
jonnybadboi9's Avatar
I am with PatrickGSR94 on this one... one of the sides on the disk DOES stick out farther than the other to fit in between the pressure plate and flywheel.
Cambocheen!
Jan 24, 2010 06:12 AM
95LssTeg
May 12, 2006 12:16 PM
methanemotorworks
Feb 13, 2006 07:32 PM
DPSJosh
Aug 26, 2005 06:09 AM
