help: power steering
Old Aug 30, 2008 | 12:54 PM
NeverLift's Avatar
Default help: power steering
can i take off my power steering just by cutting off the belt? or do i have to remove the pulleys to?
Old Aug 30, 2008 | 03:53 PM
NeverLift's Avatar
Default Re: help: power steering (NeverLift)
anyone?
Old Aug 30, 2008 | 08:13 PM
twinksack's Avatar
* B A N N E D *
why dont you remove the belt instead of cutting it
Old Aug 30, 2008 | 10:41 PM
NeverLift's Avatar
Default Re: help: power steering (twinksack)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by twinksack &raquo;</TD></TR><TR><TD CLASS="quote">why dont you remove the belt instead of cutting it</TD></TR></TABLE>
well....cutting it is my first option since i aint got the muscle to pull it off. and is it okay to just leave the pulleys or will they fly off when im driving? and does the same go for the a/c belt too?
Old Aug 30, 2008 | 10:52 PM
SuckMyDOHC's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by NeverLift &raquo;</TD></TR><TR><TD CLASS="quote">
well....cutting it is my first option since i aint got the muscle to pull it off. and is it okay to just leave the pulleys or will they fly off when im driving? and does the same go for the a/c belt too?</TD></TR></TABLE>
You don't need muscle, you need brains. Its pretty easy to loosen it up to remove the belt.
Old Aug 30, 2008 | 11:20 PM
NeverLift's Avatar
Default Re: help: power steering (SuckMyDOHC)
ok but you guys didnt answer the most import question of all...
is it ok to leave the pulleys on after i removed the a/c belt and power steering belt?
Old Aug 30, 2008 | 11:25 PM
Kendall's Avatar
Think real hard about this one for a minute. If you take the belt off, nothing is spinning the pump. If you take the pulley off, nothing is spinning the pump.
Old Aug 31, 2008 | 08:24 AM
BoSox46GSr's Avatar
Default Re: (Kendall)
Work smarter not harder... TO YOU
Old Sep 28, 2008 | 02:12 PM
NeverLift's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Kendall &raquo;</TD></TR><TR><TD CLASS="quote">Think real hard about this one for a minute. If you take the belt off, nothing is spinning the pump. If you take the pulley off, nothing is spinning the pump.</TD></TR></TABLE>
ok smart guy... if i take off the belt, the pulley is still there. if i take off the pulley nothing happens.
guys, i just want a straight answer... is it safe to removed the belt only and have the pulley still on?
Old Sep 28, 2008 | 06:46 PM
swgateg's Avatar
yes
Old Sep 28, 2008 | 07:07 PM
jdmminds's Avatar
Default Re: (swgateg)
Yes it is safe but what is the reason??? you are still going to have the weight of the pulleys and are just going to have a harder time driving with no power steering, the only reason to remove it is if it is leaking from the rack n pinion or something...
Modified by jdmminds at 1:43 PM 9/30/2008
bseries637
Oct 8, 2008 06:32 AM
gsr1289
Jun 18, 2008 11:50 AM
turbotime
May 27, 2006 04:54 PM
flip1199
Sep 17, 2003 09:27 PM
Chris93Si
Apr 20, 2003 09:08 AM
