Vibration Problems
Old Sep 3, 2008 | 06:25 PM
hardvtec90's Avatar
Default Vibration Problems
I have this vibration feel under acceleration. Any time i have the gas pedal engaged it feels almost like I'm running something over.
I've:
Changed the CV axles
Got New Wheels/Tires (I've had 3 different sets of wheels/tires on this car nothing changes)
Tires are Balanced
I'm kind of stuck on what to do next. I was told the axles would take care of the problem, but no luck. Any suggestions or answers?
I'm thinking the problem could lie in either my Struts, Coilovers, or Motor Mounts but I really have no clue...
Anyone
Modified by hardvtec90 at 9:10 PM 9/3/2008
Modified by hardvtec90 at 6:02 AM 9/4/2008
Old Sep 3, 2008 | 09:24 PM
n1WanteD's Avatar
Default Re: Vibration Problems (hardvtec90)
Is your motor swapped? do you have strut bars?.
Old Sep 3, 2008 | 10:57 PM
faejai's Avatar
Default Re: Vibration Problems (n1WanteD)
check your mounts? my car had same problem, felt like my motor was hitting the firewall, checked rear mount n it was changed it and feels a whole lot better.
Old Sep 4, 2008 | 05:00 AM
hardvtec90's Avatar
Default Re: Vibration Problems (faejai)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by n1WanteD &raquo;</TD></TR><TR><TD CLASS="quote">Is your motor swapped? do you have strut bars?.</TD></TR></TABLE>
Original Stock C1 everything looks factory, and nothing was tampered with. I have an spw rear strut tower bar, but that would have nothing to do with my front end vibrations. The factory strut tower bar is still there. Like I said it's pretty much all factory
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by faejai &raquo;</TD></TR><TR><TD CLASS="quote">check your mounts? my car had same problem, felt like my motor was hitting the firewall, checked rear mount n it was changed it and feels a whole lot better.</TD></TR></TABLE>
Sounds like I'll be checking the mounts next After you changed the mount do you still have any vibration?
Anyone know if it could have anything to do with the struts or coil overs? I have KYB AGX on Ground Control Coilovers
Old Sep 4, 2008 | 05:26 AM
wrx-killer-Sti-eater's Avatar
From: 99 probs but a stolen car aint 1, ca, cerritos/fullerton
bad wheel bearings, check those too. happen to me before.
VIS250P
May 28, 2007 08:52 PM
Hwj_33
Aug 17, 2006 09:35 PM
SGVridgerunner
Dec 21, 2005 08:41 PM
Coltrane
Feb 22, 2005 08:22 PM
