idle/vtec problem
Old Aug 31, 2008 | 08:22 AM
D_koschak's Avatar
Default idle/vtec problem
I have a 96 integra gsr and it is running like crap my car wont engage into vtec so i probed all the wires everything checked out good, ran new vtec wires and still nothing, swapped out 4 different vtec solenoids with oil pressure sensor and still nothing, had the tune checked and that checked out fine, had the ecu gone threw and they said it tested fine, and with the idle problem evertime i come to a stop sign my car dies and it misses really bad underload so i changed to new plugs, wires, cap and rotor and still runs shitty this has been an endless battle with these 2 things all summer and need to get it fixed so if anyone knows what it cold be that would be great thanks
Old Aug 31, 2008 | 08:27 AM
BoSox46GSr's Avatar
Default Re: idle/vtec problem (D_koschak)
Did you check all your vacuum lines, oil, ignition timing???
Old Aug 31, 2008 | 08:49 AM
D_koschak's Avatar
Default Re: idle/vtec problem (BoSox46GSr)
vac lines are good, oil pressure is at 70lbs at cold idle, and im waiting on my new distributor to try that
naha08
Feb 17, 2006 01:13 AM
JDMFREAK2002
May 30, 2005 08:27 AM
mr_vtec
May 6, 2005 01:33 AM
