95 gsr not running right....help...??
Hey, i have a 1995 integra gsr and its been running fine up until about a week ago. At first while i was driving it was just skip and sputter like i had bag plugs or wires, changed those just out of curiosity, but then it just got worse. As i was driving up a hill the car wouldn't go i had the gas to the floor and the car started popping and then it died...started right back up, i drove it for about 5-10 minutes with it skipping not on a hill or anything just flat ground,it was popping and skipping really bad until it died again, and then it wouldn't start. I left it there over night and went back in the morning. The car started right up, drove fine no problems at all for 20ish minutes, then everything started again the rpms would drop really low almost to where the car would shut off when i was pushing the gas, it died again the it wouldn't start, it had it towed behind a truck to my house. Before it only had problems when i pushed the gas now if you start the car and just let it sit in will sputter and the rpms will drop really low almost to where it dies then it jumps right back up then eventually it will die out. It only seems to run bad after warming up. CEL code for knock sensor, changed it did nothing.
Re: 95 gsr not running right....help...?? (frisbie21789)
limp mode on a obd1? is the engine miss firing? with the car running take a spark plug out and see if it changes idle. if it doesnt its probably something related to that cylinder.
