help swap!
Old Sep 3, 2008 | 04:43 PM
Mr.vang's Avatar
Default help swap!
i just what to know how to swap a 0bd2 ls motor into a
0bd1 integra?
Old Sep 3, 2008 | 04:47 PM
Tarmac Junkie's Avatar
Default Re: help swap! (Mr.vang)
SEARCH...
Old Sep 3, 2008 | 04:52 PM
Mr.vang's Avatar
Default Re: help swap! (Tarmac Junkie)
where?
Old Sep 3, 2008 | 05:07 PM
Click the red SEARCH button in the upper right had corner of the page, then under "Search For" type obd2 to obd1. Under "Forum" type Hybrid. Under "Data Set" click Archived Content. Then click NEXT. I just did it and got 80 hits on that subject. Some are on wireing, some about what you will need for the swap.
Old Sep 4, 2008 | 05:35 AM
be18see1's Avatar
you just take the harness off the obd1 motor and plug it into the obd2 motor. you also need obd1 injectors and an obd1 dizzy.
Old Sep 4, 2008 | 11:55 AM
egsleepercivic's Avatar
Default Re: help swap! (be18see1)
if you use the obd2 harness it will be plug and play, and you will be able to use the obd2 injectors and dizzy and still run obd 1
Old Sep 4, 2008 | 12:46 PM
Mr.vang's Avatar
Default Re: help swap! (egsleepercivic)
i dont get what u guys r saying!
what i need to do to the 0bd2 ls motor so it well drop rite into a DA 0bd1 shell?
i know, im using my cable tranny! and do i have to use my old 0bd1 dizzy for the 0bd2 motor? and what else do i need to do?
DC206R
Mar 6, 2009 09:56 PM
turbo2001gsr
Dec 15, 2008 12:08 PM
Jhonny Ricer
May 28, 2007 12:02 AM
hayn420
Feb 20, 2007 06:11 PM
B18C1 '96 Coupe
May 21, 2003 02:25 PM
