Alignment Problem
Old Aug 30, 2008 | 03:47 AM
rbizzell30's Avatar
Default Alignment Problem
I went to shop to get my car aligned and they told me that my caster needs to be replace. The car pulls to the right really bad. They said I need to get that fixed. Is the caster a a single part of the suspension or do I have to replace control arms and camber ?????
Old Aug 30, 2008 | 06:05 AM
m735is's Avatar
Default Re: Alignment Problem (rbizzell30)
Didn't they tell you what would need to be replaced?
What suspension are you using? Stock? Aftermarket?
What wheels and tires?
Old Aug 30, 2008 | 06:21 AM
hatchling37's Avatar
Caster is not a part. Caster is a measurement of the angle of a line that passes through the center of your ball joints and its deviation from straight vertical.
It's quite possible you have a bent control arm. Do you have your alignment specs?
Natsu09
May 31, 2018 10:26 AM
Integritycaptain90
May 22, 2008 06:23 AM
Blamm!!
Apr 7, 2008 04:34 AM
justin.parker
Apr 5, 2007 08:33 PM
Type R1
Apr 24, 2002 05:14 PM
