need pro help
Old Sep 2, 2008 | 06:55 PM
gsr96cx's Avatar
Default need pro help
My valves were ticking bad so i had a friend do a valve adjustment, after that it was still ticking. It ticks so bad even the distrubutor ticks. I took the head apart and I didn't find any bent valves. Does anyone know what else can be causing the tick? Its coming right from my gsr head.
Modified by gsr96cx at 5:32 PM 9/3/2008
Old Sep 2, 2008 | 07:55 PM
dohczccrx's Avatar
Default Re: need pro help (gsr96cx)
lack of oil to the head
Old Sep 2, 2008 | 08:55 PM
egsleepercivic's Avatar
i hear lma's make noise like ticking when they are done, my b16a always ticked even after adjustments and compression always showed good....something to look into
Old Sep 3, 2008 | 10:01 AM
gsr96cx's Avatar
Default Re: (egsleepercivic)
lma's? What do you mean lma's? I'm kind of a noob so i dont really know what you mean by lam's.
Old Sep 3, 2008 | 11:10 AM
Lost Motion Assembly
Old Sep 3, 2008 | 04:31 PM
gsr96cx's Avatar
lack of oil: can a bad oil pump cause this? My oil pump seems fine. The tick before i had my friend do the valve clearance before was just a slight sound but after he did the valve clearance its ticking so loud its almost like a rattle. Even the distrubitor is rattleing. Anyone have any idea?
Old Sep 3, 2008 | 04:46 PM
Tarmac Junkie's Avatar
Default Re: (gsr96cx)
It realy sounds like LMA"S. They are a glorified lifter. They keep the rocker arms from slapping the cam when the motor isn't in vtec. To check them pull the valve cover and push on them, if they have good pressure they are probably good, on the other hand it they don't have good pressure or don't return all the way they are bad. I have had these go bad on 2 motors in one year. It sucks, the only place that I could but them new was the dealer.
rondogg779
Oct 28, 2019 11:19 PM
Jhicks
Feb 3, 2012 05:58 AM
JDMx206
Nov 27, 2008 09:22 AM
lowboost civ
Feb 28, 2003 05:48 AM
