Problem with my DD
Old Dec 22, 2008 | 04:12 AM
Ed 341's Avatar
Default Problem with my DD
Beware Tech content below!:
I have a 2000 Integra GS sedan w/180K which I use as a daily/beater but I can't get then damn thing started. It did the same thing about 3 weeks ago and I assume it is something to do with the igntion. I replaced the Igntion coil which seemed to fix it until yesterday.
Basically the car attempts to turn over but doesn't actually run. I checked the fuses, the fuel pump primes. I also replaced the fuel filter, spark plug wires/cap and rotor along with the new ignition coil. Jump starting it doesn't help either.
I'm not sure why it would be fixed and then have the same problem a couple weeks later! Please let me know if you have any ideas.
-Ed
Old Dec 22, 2008 | 05:59 AM
citrus3000psi's Avatar
Default Re: Problem with my DD
-Ed
You would have gotten better/more responses if you said this car was an ITR. Take your dizzy apart? The rotor screw didn't back out did it?
Old Dec 22, 2008 | 06:14 AM
Ed 341's Avatar
Thanks, I will check that as soon as possible.
I assumed enough people knew who I was that it wouldn't matter!
Old Dec 25, 2008 | 02:38 PM
jeff652's Avatar
Twenty Bucks says it's the ignitor. There always fail on the older/higher miles Civics/Integras. It's inside the distributor, right next to the coil that you just replaced.
If not that, then most likely the main relay.
Old Dec 26, 2008 | 11:58 AM
FoW*Shadow's Avatar
JDM_Certified
Jun 29, 2009 01:42 AM
GuitarPunk015
Jun 25, 2009 03:24 PM
paboy
Jul 24, 2008 05:29 AM
Tony R
Jun 15, 2004 07:09 AM
drone88
May 11, 2004 02:14 PM
