Help please
Old Dec 29, 2008 | 12:59 PM
92IntegraPOS's Avatar
Default Help please
I searched and searched and searched. Car wont crank. New starter new battery. Starter clicks sounds like it wants to start. No spark. I DONT Hear the fuel pump coming on in ACC position. Could it be a bad ECU? or my fuel pump relay is bad. If so where can I start looking. Where is the fuel pump relay? Its strange though because I did bump start it to get it from my friends house to my house and it started and ran great from his house to my house which is about 20 miles. It just wont start.
1992 Integra
B18
STOCK
Old Dec 29, 2008 | 05:05 PM
hondarules7's Avatar
Default Re: Help please
hmmm seems very odd, im sure you've done this already but try checking all your grounds such as you battery contact and any other ground in the engine bay (using a multimeter). if your putting 12v to the starter then 12v has to go to ground and if only 6v is going to ground then it wont start...
Old Dec 29, 2008 | 05:17 PM
scbmx87's Avatar
Its not your fuel pump relay. If it was, you wouldnt have been able to keep the car running after you bump start it. My money is on a bad ground on the starter or battery. Or maybe an ignition fuse. Main relay is also a possibility.
Old Dec 30, 2008 | 08:36 AM
update for some random reason i decided just to check the ground from the valve cover to the body and sure enough it was bad. I jumped it with a good wire and it started up. i have never heard of anything like that before. haha
Jlove1993
Feb 3, 2015 09:43 AM
97civic07gsxr
21
Feb 8, 2009 02:33 PM
alpinekllr
Jan 13, 2009 12:35 PM
deftones0817
Jul 14, 2005 08:17 AM
I3ackfire
23
May 9, 2004 07:30 PM
