wire harness question
Old Dec 21, 2008 | 11:20 PM
B18CUL8R's Avatar
Default wire harness question
scenario
-97 integra
-i pulled out the stock obd2a engine and engine wire harness to do a motor swap
-i want to simply put in my obd1 motor and use the obd1 harness that came with it since my obd2a harness is kinda f*ked up.
-i know the obd1 engine harness plugs and the obd2a integra shock tower plugs will plug into each other.
-i just need to know if the pinouts are the same. i dont want to burn an ecu and im too lazy to check the pinouts myself. does anyone know if i have to move any pins to a different location on any of the plugs? or are they fine to just plug and play.
TIA
merry christmas
Old Dec 22, 2008 | 04:26 AM
weavertime1's Avatar
Default Re: wire harness question
You need a jumper harness that allows you to use an OBD1 ecu with your OBD2 firewall harness, unless you plan to replace the whole firewall harness which would require quite a bit of work. Other than that you should be fine. Check with your state's DOT as some states do not allow the use of an OBD1 system on an OBD2 car (basically because they can not hook up the OBD2 diagnostic device). Good luck!
Old Dec 22, 2008 | 05:06 PM
B18CUL8R's Avatar
yes i do have an obd1 ecu and jumper
this might help explain what im trying to figure out
Old Dec 22, 2008 | 06:41 PM
Yes, unless you have a GSR...then the mysterious 4th plug has 2 pins in an OBD1 car and 3 in an OBD2 car. I don't know what that 4th plug does, but I promise it is different. Good luck!
BTW is that hair coming from your intake? ;]
Old Dec 22, 2008 | 07:50 PM
B18CUL8R's Avatar
ok so i dont have to move any of the pins around?
oh yeah thats my hair looking wire harness hahaha
Old Dec 23, 2008 | 04:21 AM
I know this for sure...I had an OBD1 hatch, and I used a complete swap from an OBD2 integra ls (including the harness), and everything worked fine. I see no reason that it would not be the same the other way around as well, as long as you are using an OBD1 ecu. If you did what you are doing and tried to run an OBD2 ecu it would have a few codes. Good luck!
Old Dec 23, 2008 | 09:58 AM
B18CUL8R's Avatar
ok cool thats all i needed to hear. sounds like it should work. i have an obd2a car, with a complete obd1 swap & harness. obd2a ecu converter and a obd1 chipped p28 (engine is a lsvtec).
i just dont wanna plug in my ecu and try start up my car and end up with a fried ecu
jaron_cc
May 21, 2009 10:43 AM
hfrex
Dec 14, 2008 08:35 PM
CivicB18C1
Jun 13, 2008 05:47 PM
gsrious
Nov 19, 2006 10:31 AM
TeamSTEALTH GSR
Aug 10, 2003 02:58 AM
