Code 43
Old Dec 24, 2008 | 07:08 PM
roc0487's Avatar
Default Code 43
I installed a new throttle body, and the car ran great after no TPS sensor for a few months ( I bought the car without one) and I'm throwing a code 43 (fuel supply system). The CEL comes on at random and then the car starts to sputter and run like ***, but some of the time when the light isn't on the thing runs perfect... Guys, please help.
Old Dec 24, 2008 | 07:23 PM
neardon's Avatar
I'm a Jackass
Default Re: Code 43
sell ur car n buy a mustang, they run better
Old Dec 24, 2008 | 07:32 PM
roc0487's Avatar
Default Re: Code 43
dude, don't interrupt my post with useless ****... please.
The kicker here is that my girl has a 95 V6 and it runs like **** too lol so I'm lost in this whole situation. I sit here and browse these forums like a ****in mad man and still no solution.
Old Dec 24, 2008 | 08:27 PM
Arsenal's Avatar
Default Re: Code 43
When I had a 43, replaced m o2 sensor and it went away/
Old Dec 24, 2008 | 08:38 PM
uses0ap's Avatar
Default Re: Code 43
el oh el
Old Dec 24, 2008 | 08:47 PM
romJones's Avatar
Default Re: Code 43
likewise...
i even went as far as replacing my fuel filter
try those & let us kno how it goes!
Old Dec 25, 2008 | 12:46 PM
roc0487's Avatar
Default Re: Code 43
thanks gentlemen, I'll see what I can do... I have 2 O2 sensors. How will I find out which is the bad?
Old Dec 25, 2008 | 06:50 PM
Arsenal's Avatar
Default Re: Code 43
By getting the code. If your OBD 2 you will have a series of numbers, 5 digits I believe. If your OBD1, you only have one sensor.
Old Dec 26, 2008 | 12:05 AM
DA9_SE's Avatar
Default Re: Code 43
I don't know which Integra you have, but according to my OEM Service Manual for the DA series; CODE 43 is fuel supply system or O2 sensors.
If it's the fuel supply system, here is the troubleshooting guide.
Note: The sources of a symptom are ranked in the order they should be inspected starting with (1).
ROUGH IDLE
(1) fuel injectors
(2) contaminated fuel
POOR PERFORMANCE
*Misfire or Rough Running
(1) fuel injector
(3) pressure regulator
*Fails Emission Test
(1) pressure regulator
(2) fuel injector
*Loss of Power
(1) fuel pump
(2) fuel filter
(3) fuel injector
FREQUENT STALLING
*While Warming Up
*After Warming Up
Good luck!
Old Dec 26, 2008 | 05:29 PM
roc0487's Avatar
Default Re: Code 43
thanks a lot bro, it's a 94 LS... but those definitely help!
SlowB20z
Engine Management and Tuning
Dec 28, 2012 09:12 AM
JDM_SOHC
Apr 12, 2009 02:38 PM
jrwhites
Jul 15, 2008 03:37 PM
DarkBB4
Aug 27, 2005 09:31 AM
DC2EGHB
13
Mar 18, 2004 05:44 AM
