simple question
Old Feb 12, 2004 | 07:31 PM
b18c1wes's Avatar
Default simple question
my car is set to run rich by the vortech fmu.. will this hurt any thing on the engine? my af gauge reads like 3 from full rich on my a/f gauge....its set this way to protect the engine because its turbo but not dyno tuned with hondata yet....
Old Feb 12, 2004 | 07:34 PM
DaX's Avatar
DaX
Loved
Community Favorite
Default Re: simple question (b18c1wes)
Your gas mileage goes poopie with an FMU. Rich conditions are safer than lean conditions though.
Old Feb 12, 2004 | 07:47 PM
b18c1wes's Avatar
ya i can deal with that better to have bad gas mileage than a blown motor
Old Feb 12, 2004 | 07:51 PM
DaX's Avatar
DaX
Loved
Community Favorite
Default Re: (b18c1wes)
Don't the wrong idea from me though...I hate FMU's. Jacking your fuel pressure up above 100 psi is no good. If you have too much pressure it can make the injectors have to work very hard to open. Your fuel system was not designed to operate at that high of a pressure.
Old Feb 12, 2004 | 08:41 PM
b18c1wes's Avatar
i have a walbro fuel pump with a gauge and its at like 45 50 psi
Old Feb 12, 2004 | 09:01 PM
twkdCD595's Avatar
@ idle.
when you get into boost you start adding pressure... ex a 10:1 fmu will add 10 psi fuel pressure per 1 psi boost pressure.
so @ 5 psi your adding 50 psi of fuel pressure to your base 45 psi = 95, lots of fuel pressure still.
just an fyi to not go to crazy wiith boosting on the fmu... too much pressure is bad and it does not take much to add up to 100+ psi of fuel pressure.
Old Feb 12, 2004 | 09:08 PM
b18b1hmtlove's Avatar
Cost of FMU=$80-100
Cost of Chipping your ECU and having someone send you a Chip: $50
Any questions?
Old Feb 12, 2004 | 09:10 PM
b18c1wes's Avatar
getting it dynotuned by secret services in tampa with hondata when i get the money (like a month or 2) i should be good till then right ill be replacing the injectors before i tune it prob.....
Old Feb 12, 2004 | 09:12 PM
b18c1wes's Avatar
even when i get it tuned im not boosting over 5-7lbs 5 is enough for me and ill get more hp when i tune it
spooledhonda
Jan 3, 2006 03:23 PM
musclefella
May 1, 2004 01:31 AM
b16ahybrid
Nov 28, 2002 07:51 PM
BorderM3
Nov 5, 2002 10:54 AM
cool
Mar 1, 2002 01:33 PM
