is this "clocked" enough?
Old Feb 12, 2004 | 01:20 PM
RedStarGsr's Avatar
Default is this "clocked" enough?
i know you need the oil send / return up and down, and im pretty sure i had it that way when it first fired her up, but i think shes been moving.
my question is...if i tighten them down extremely tight now, is this clocked enough or does it need to be 100% strait up and down. thanks in advance.
Old Feb 12, 2004 | 01:23 PM
B18EG6's Avatar
Default Re: is this "clocked" enough? (RedStarGsr)
How does the return look?
Old Feb 12, 2004 | 01:24 PM
rondigs's Avatar
Its hard to tell from those pics. Generally your more concerned with the oil draining out of the turbo; opposed to the oil feed pictures you posted.
Old Feb 12, 2004 | 01:25 PM
rtype11's Avatar
looks allright, you know the idea, the turbo feed looks close the manifold, if you feel like it you can try a heat reflective sleeve over the feed - steal one from a VW motor, they have tons of it or get a 30degree fitting so you can angle the feed away slightly forward. how close is the DP to the rad, in the pic looks pretty close, probably just the picture.
Old Feb 12, 2004 | 01:28 PM
RedStarGsr's Avatar
best one ive got of the oil return layin around...
the downpipe isn't really that bad. you guys think im safe?
Old Feb 12, 2004 | 01:43 PM
rtype11's Avatar
Default Re: is this "clocked" enough? (rtype11)
yeah looks pretty good from here
Old Feb 12, 2004 | 01:47 PM
PrecisionH23a's Avatar
I cannot really tell from the angle of the picture, but a good rule of thumb is to not exceed a 15 degree angle when clocking the center housing.
Old Feb 12, 2004 | 02:03 PM
minivan81's Avatar
Default Re: is this "clocked" enough? (PrecisionH23a)
It looks fine.
FOrSfEd
Feb 1, 2004 04:33 PM
mattcalica
Aug 16, 2003 06:20 AM
ntegls
Apr 5, 2003 02:07 PM
incogNitto
Jan 22, 2003 08:46 PM
DIY_Racing
Dec 15, 2002 06:41 PM
