cam seal leaking???
Old Feb 15, 2004 | 03:27 PM
bluesi00's Avatar
Default cam seal leaking???
i took off my distributor cap and there was oil in it. do u guys think its the cam seal?? is that easy to fix? has anyone changed theres??
Old Feb 15, 2004 | 03:40 PM
Bulldogg83's Avatar
Default Re: cam seal leaking??? (bluesi00)
haven't changed one but heard that it only cost's $5-$10 from Honda and it's really not that hard to do.....
Old Feb 15, 2004 | 03:54 PM
bluesi00's Avatar
yeah, i bought the seal already. does anyone know a site to where i can get detailed instructions on how to install one fora 00 civic si?? thanks
Old Feb 15, 2004 | 06:48 PM
roydogg's Avatar
Default Re: (bluesi00)
http://icelord.net/honda/repair/
Old Feb 16, 2004 | 09:46 PM
bluesi00's Avatar
cant find it. u know another site??
Old Feb 16, 2004 | 09:59 PM
roydogg's Avatar
It's not hard at all. Just take the valve cover off and look at the cam seal part and take the 2 top bolts off and pop it off. Do a search , has been covered plenty of times thats why you haven't gotten to many replies.
Old Feb 18, 2004 | 10:10 PM
bluesi00's Avatar
i've done the search and still cant find it. also does anyone know what the name is of the hondabond that they sell like at autozone??
Old Feb 18, 2004 | 10:18 PM
Silverbeast's Avatar
There is some grey stuff VatoZone sells, that is similar to Hondabond. I would replace it with a GE cam plug, they are fairly cheap and worth the extra few bucks. I JUST replaced mine like 2 weeks ago with an OEM unit and it was leaking again. Replaced it with a GE one 2 days ago and not a bit of a leak.
Old Feb 18, 2004 | 11:12 PM
Ek00fbp's Avatar
Default Re: (Silverbeast)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Silverbeast &raquo;</TD></TR><TR><TD CLASS="quote">There is some grey stuff VatoZone sells, that is similar to Hondabond. I would replace it with a GE cam plug, they are fairly cheap and worth the extra few bucks. I JUST replaced mine like 2 weeks ago with an OEM unit and it was leaking again. Replaced it with a GE one 2 days ago and not a bit of a leak.</TD></TR></TABLE>
GE = golden eagle?
also, c-speedracing.com has an article on changing cams and I think it would tell u how to change the cam seal as one of the steps.
Old Feb 19, 2004 | 04:35 AM
Default Re: (Ek00fbp)
Yes, the golden eagle cam plug seal.
Old Feb 19, 2004 | 04:44 AM
QCKGSR's Avatar
use the GE
Old Feb 19, 2004 | 05:24 AM
ApexiChild's Avatar
Default Re: (QCKGSR)
get the GE or STR. they both work well. OEM cam seals are notriose for leaking even if you do use a sealant...
Old Feb 19, 2004 | 11:42 AM
bluesi00's Avatar
i just figured out that the intake cam doesnt have a seal, right?? its leaking into the distributor somehow
Old Feb 19, 2004 | 11:53 AM
Stewie's Avatar
If you have oil on your distributor it's not because of the cam seal.
There's a seal on the distributor shaft that needs to be changed. It looks like an o-ring. In fact, I think it's called distributor o-ring.
Old Feb 19, 2004 | 12:47 PM
bluesi00's Avatar
lol, thanks. i took everything apart and now i see it. could it be that my distributor messed up?? i cant rev past 6k
Old Feb 19, 2004 | 02:52 PM
dfoxengr's Avatar
get a new cap and rotor. that moght help.
sinister357
Aug 21, 2007 12:01 PM
nicko360
Jan 16, 2007 07:56 AM
diversegsr
Feb 2, 2005 02:49 PM
hondaeg8
12
Aug 11, 2004 11:39 PM
blackdude
Mar 17, 2004 08:55 AM
