how much boost on stock type r?
Old Feb 14, 2004 | 02:20 PM
the jdmchop's Avatar
Default how much boost on stock type r?
i was wondering how much boost or power can i abtain from a stock j-sprc itr?
what would be a good setup?
anyone boost a stock itr?
Old Feb 14, 2004 | 03:19 PM
BoostedKrazi's Avatar
Default Re: how much boost on stock type r? (jdmchop)
B18c1/B18a1 GSR/TYPE R high compression ratio’s 6-7psi safely
B18b1/B18a1 low compression ratio’s 10-12psi safely
Old Feb 14, 2004 | 03:49 PM
Default Re: how much boost on stock type r? (BoostedKrazi)
wow what u sign up to just answer my question? lol
Old Feb 14, 2004 | 03:54 PM
FOrSfEd's Avatar
yeah 6 is good but you can run 10 with the right tuning. I will be running 10 when i get mine tuned.
Old Feb 14, 2004 | 03:56 PM
Default Re: how much boost on stock type r? (FOrSfEd)
whats a good combo to run?
Old Feb 14, 2004 | 04:01 PM
Jay Dirt's Avatar
there is no standard set safe amount of boost to run, make sure you use a good fuel system, and put together a good turbo kit, a good combo to run for turbo systems is from Full-Race Motorsports
Old Feb 14, 2004 | 07:13 PM
B18bEK's Avatar
i've seen 13psi but he was running a thicker headgasket. i think he made 318hp 218tq ..
Old Feb 14, 2004 | 08:19 PM
Nid Styles's Avatar
Default Re: (B18bEK)
Depends on your set-up, and tuning.
I'm sure you could run 20psi with the right turbo, and management
Old Feb 14, 2004 | 08:31 PM
MiraiZ's Avatar
Default Re: (nd_styles)
I wouldn't do anymore than 5psi on a stock JDM R (from experience)
Old Feb 14, 2004 | 09:12 PM
HYREV2NR's Avatar
Go to Hondata.com & look @ the SC'd 98 R with 11 psi of boost. I think it's something like 262 whp. I could have a lotta fun with that.
Old Feb 14, 2004 | 09:42 PM
vtec.dc2's Avatar
if you want it to last for a while, keep it within low 200's
Old Feb 14, 2004 | 09:51 PM
B18bEK's Avatar
i say get a thicker head gasket, turn it up, stick with 300 and just dont' go too crazy with hondata of course!
Old Feb 14, 2004 | 10:01 PM
BoostedITR41's Avatar
<---- 84k miles stock internals, inline pro head gasket and block gaurd, FMU, missing link, 255lph fuel pump, vafc and 450cc injectors I ran 15psi all day on 93 octane and went 13.0@109mph on street tires and stock exhaust on that set up.
Old Feb 14, 2004 | 10:09 PM
G
sh!t happens.
Default Re: (BoostedITR41)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BoostedITR41 &raquo;</TD></TR><TR><TD CLASS="quote">&lt;---- 84k miles stock internals, inline pro head gasket and block gaurd, FMU, missing link, 255lph fuel pump, vafc and 450cc injectors I ran 15psi all day on 93 octane and went 13.0@109mph on street tires and stock exhaust on that set up. </TD></TR></TABLE>
nice set up abd numbers.... have you dynoed it yet..
Old Feb 14, 2004 | 11:20 PM
Chillinit's Avatar
u ran 15 psi all day...how about on the street??!!?? Thats the thing...ur typer might be able to handle 15 psi with proper fuel management...but how long is ur **** gonna last....not too long!!
Old Feb 14, 2004 | 11:25 PM
integRated109's Avatar
Default Re: (Chillinit)
made 265WHP/195TQ totally untuned, basic drag kit FMU setup, 7PSI(and blew it up on 10psi )
Old Feb 15, 2004 | 07:38 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Chillinit &raquo;</TD></TR><TR><TD CLASS="quote">
u ran 15 psi all day...how about on the street??!!?? Thats the thing...ur typer might be able to handle 15 psi with proper fuel management...but how long is ur **** gonna last....not too long!! </TD></TR></TABLE>
all day everyday for the entire summer. and that is mish mash fuel system. base timing was set at 13 degrees no BTM. I am goin hondata this year but people have made that last on cars over 100k miles....the head gasket drops compression a full point
Old Feb 15, 2004 | 07:54 PM
TurboJesse
Guest
Posts: n/a
If you can drop the comp. which the headgasket does, the internals will have no problem handling 300+/- WHP.
Old Feb 15, 2004 | 07:57 PM
Type-ARR's Avatar
Default Re: (Mpir3)
Thick headgasket + 10 psi and 300+ whp what else do you need...?
Old Feb 29, 2004 | 12:24 PM
smoothCTR96's Avatar
bump
Old Feb 29, 2004 | 12:52 PM
swlabhot's Avatar
Bone stock B18C6, 11.1 cr @ 10psi street tuned afr only. Timing static retard 4deg... Fuelling by AFC hack. Running for a year now... Its my only driver, shopping trolley AND track car. Both 10psi street, shop or track
Old Feb 29, 2004 | 01:05 PM
alpha's Avatar
Get some ARP or AEBS head studs to keep the head from lifting when you go into boost. That with Hondata/Uberdata/EMS, larger injectors, T3/T04E 50 trim compressor wheel with a .48 A/R turbine housing and a Cometic head gasket you should be able to lay down 280WHP with a good tune.
Old Feb 29, 2004 | 01:48 PM
hulkhb's Avatar
Default Re: how much boost on stock type r? (0x64)
after i hit the dyno i'll share my numbers, gona be running 8psi daily.
BadMaka
May 28, 2009 08:47 AM
JDM_Acccord
Jul 5, 2007 03:24 AM
boosted k20
Mar 8, 2005 01:31 PM
dmah
Jul 22, 2003 08:33 PM
1EK1EG
Nov 5, 2002 10:28 PM
