Faced with a tough decision..
Old Feb 11, 2004 | 03:34 PM
5thgencivic's Avatar
Default Faced with a tough decision..
Hey guys, I had my car tuned last week. It wasn't the tune I wanted so I'm heading back to get it retuned at another shop(richen it up). I hit around 250 at 12psi on a dynojet with my D16Z6. Since then I've removed the cat which should make up for the conservative tune so numbers should be close to what they were.
Anyway, I've been really struggling to make a decision. Sleeves are stock, block is posted. Do I up the boost until I hit 300whp? Or just stay around 250 and not worry? I'd rather have a motor to boost than no motor at all.. my original goal when starting the project was to hit 300, but after seeing the money and time that has gone into this project I dunno.. It has held at 250 with a bad tune, so I would think it would hold at 300 with a good tune. Sleeves are the only limiting factor besides the stock head and stock intake manifold What do you think? Thanks for your input.
Nate
Old Feb 11, 2004 | 03:41 PM
Mase's Avatar
Default Re: Faced with a tough decision.. (5thgencivic)
just make sure your tuner is competent
Old Feb 11, 2004 | 04:14 PM
Default Re: Faced with a tough decision.. (Mase)
He is
Old Feb 11, 2004 | 04:36 PM
aka010010
Guest
Posts: n/a
250 is good. the block...is it stock or no?
Old Feb 11, 2004 | 04:41 PM
Default Re: (aka010010)
Sleeves are stock. CP pistons and eagle rods. Probably won't make the decision until the car is on the dyno It's up to me, but I hate making the call..
Old Feb 11, 2004 | 06:06 PM
Mase's Avatar
Default Re: (5thgencivic)
you're safe to 350, easy.
just watch and make sure your tuner is on target
Old Feb 11, 2004 | 06:26 PM
dfoxengr's Avatar
OT: what posts did you use for the block?
Old Feb 11, 2004 | 06:27 PM
ahobbs's Avatar
HELLO,GOOD MORNIN'
Default Re: (Mase)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mase &raquo;</TD></TR><TR><TD CLASS="quote">you're safe to 350, easy.
just watch and make sure your tuner is on target</TD></TR></TABLE>
most important peice of equpiment.
Old Feb 11, 2004 | 06:46 PM
Default Re: (HybridcivicLS-T)
I'm gonna go for it then... It's a sohc, blocks are cheap
hybridvteceg, they are the posts from ENDYN. Some say good, some say bad about posting. If I would have done it again I would have left the block completely stock. If it's held up to 250, I don't see a problem with a little more. Friday the 13th is tuning day, but it's all good
Old Feb 11, 2004 | 06:54 PM
dfoxengr's Avatar
yeah im posting a DIY ls build im doing with endyns. thanks
Old Feb 11, 2004 | 07:48 PM
Bailhatch's Avatar
Default Re: (hybridvteceg)
I don't think the head and IM are going to be restrictions @300whp.
If your tune is decent I would run it at about 320whp with what you have. The torque you'll have with the 320hp would be just awesome!! 250tq maybe? I would do 260+hp stock block myself.
Old Feb 12, 2004 | 12:02 AM
Default Re: (Bailhatch)
ok, I'll post up my sheet when I get back on friday along with some vids
KidFrost
14
Sep 19, 2010 02:37 PM
jibahjab'in
12
Sep 25, 2009 06:31 AM
wfocrx
Aug 15, 2006 12:43 AM
JDM91EF2
Jun 4, 2006 05:48 PM
89 EF Si
Feb 12, 2005 11:35 PM
