Stock psi?
Old Feb 12, 2004 | 09:01 AM
hondafanatic1's Avatar
Default Stock psi?
Does anybody know what the wastegate actuator on a 1st gen talon tdo5h is set at for psi. I really need to know.
Thanks
Old Feb 13, 2004 | 03:49 AM
Default Re: Stock psi? (hondafanatic1)
Nobody knows what this is?????????
Old Feb 13, 2004 | 04:25 AM
LostCRX's Avatar
you're going to get mix informatio from everybody, why don't you test it out yourself? Do you have an air compressor at home? you can do test it with a boost gauge using the air compressor. Have the compressor turned up about 10 psi, find away to connect it to your wg and boost guage. If you don't have a compressor, get a bycicle pump.
Old Feb 13, 2004 | 04:27 AM
Adriano's Avatar
Default Re: Stock psi? (LostCRX)
Stock boost on a 1G is 12-13lbs. BUt like the guy above, everyone says they got different result. I think there was a thread on this before.
Jockobo
Jan 24, 2005 08:42 AM
G3NR8
Aug 19, 2004 05:45 PM
alpha_1
Jul 30, 2004 11:39 PM
n1neb4ll
Jun 20, 2003 07:11 AM
