MSD 6 BTM wiring installation
Old Feb 12, 2004 | 01:49 PM
USDM 4G VTEC's Avatar
Default MSD 6 BTM wiring installation
i am getting my MSD 6 BTM wired and reasy to go
i am currently working on making the wire harness that wil go inside the distribuitor into the MSD
my question!
How & what methods have u guys used to make wires fit, work, not come loose, conect and be reliable inside the distribuitor and using the stock distribuitor cap
i have been trying to find a way to clear the cables and have enough room inside dizzy to make wires fit and to avoid any cutting or anything but no luck..
theres basically no space!
what have u guys done about this?
Old Feb 12, 2004 | 03:13 PM
psi420's Avatar
I removed the coil from inside the distributor, and that leaves plenty of room for routing wires.
Just make sure the rotor and all other moving parts dont come near your wires.
Use small 16-18AWG eyelets (sp) for your connections.
Old Feb 12, 2004 | 04:01 PM
Default Re: (psi420)
the BTM still needs the coil to be wired to it
did u installed that externally???
if so, how the hell u get the signal to the center of the rotor in order to get spark to the plugs???
Old Feb 12, 2004 | 04:39 PM
psi420's Avatar
Default Re: (USDM 4G VTEC)
I hooked up a external coil, w/ a new MSD Cap made for an external coil.
Old Feb 15, 2004 | 10:45 AM
any one else
jazmie
Apr 1, 2010 01:14 PM
zephyrantes
Mar 12, 2005 05:35 AM
AznBlueBoy
Jul 8, 2004 02:25 PM
blackacteg96
May 12, 2003 12:56 PM
_Endless_
Jan 22, 2003 12:58 AM
