Whats is the max boost with stock sensor + hondata
Old Feb 12, 2004 | 02:29 PM
vtec.dc2's Avatar
Default Whats is the max boost with stock mapsensor + hondata
(map sensor)
Too much information in archives with different answers.. from 10.65psi to 11psi.. or is it 14.7psi?
Old Feb 12, 2004 | 02:37 PM
Kataku2K3's Avatar
Default Re: Whats is the max boost with stock mapsensor + hondata (vtec.dc2)
A stock Honda map can handle ~11lbs. max...
Old Feb 12, 2004 | 02:38 PM
vtec.dc2's Avatar
Default Re: Whats is the max boost with stock mapsensor + hondata (Kataku2K3)
what happens if you run it at 11psi which is max but don't go over?
Old Feb 12, 2004 | 02:45 PM
ladysman's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by vtec.dc2 &raquo;</TD></TR><TR><TD CLASS="quote">what happens if you run it at 11psi which is max but don't go over?</TD></TR></TABLE>
OK, the stock Map sensor will read ~11lbs. You CAN run more if you want. How? just richen up the last part of the Hondata Map (Or any standalone fuel Map) for the appropriate amount of boost. I don't recommend going much higher than 11. I run 13 on mine with no problems. I was just too lazy to install the 3 bar and retune again so I just did it that way until the motor went in.
Old Feb 12, 2004 | 02:50 PM
vtec.dc2's Avatar
Default Re: Whats is the max boost with stock mapsensor + hondata (ladysman)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ladysman &raquo;</TD></TR><TR><TD CLASS="quote">
OK, the stock Map sensor will read ~11lbs. You CAN run more if you want. How? just richen up the last part of the Hondata Map (Or any standalone fuel Map) for the appropriate amount of boost. I don't recommend going much higher than 11. I run 13 on mine with no problems. I was just too lazy to install the 3 bar and retune again so I just did it that way until the motor went in. </TD></TR></TABLE>
i see, i guess i'll just stick at 10psi for now, that one psi isn't worth it.. i'll just get 3bar once i get it retuned.
Old Feb 12, 2004 | 04:39 PM
b18b1hmtlove's Avatar
you can run like 12-13psi if you are brave by just richening up the 255 map value(11.03psi) and should be okay...
Tofurky
Feb 24, 2019 06:09 AM
crazy_ls_90
Sep 10, 2008 02:26 PM
weziebme
Mar 2, 2008 02:22 PM
Kidd_Stylez
Nov 2, 2004 04:14 PM
b16 matt
Sep 21, 2004 07:00 AM
