At what point do you upgrade spark?
Old Feb 14, 2004 | 11:57 AM
Dr Pooface's Avatar
Default At what point do you upgrade spark?
Is is related to boost? Or HP?
Planning a build of my b18c5 in the next year, aiming for 15 psi/350 hp, wondering if there is any merrit of getting an msd system or something...
Old Feb 14, 2004 | 11:59 AM
Mase's Avatar
Default Re: At what point do you upgrade spark? (Dr Pooface)
w/ 350 whp, you should be fine.
probably after 400 whp, you may need an ignition upgrade
Old Feb 15, 2004 | 01:53 PM
pornstarSR's Avatar
Default Re: At what point do you upgrade spark? (Mase)
most hondas run the same ignition setup....so a jdm type R with 200- 220 hp or so
same as a dx with 90hp....
so you make the choice...i think they are good for alot....but at some point the spark is going to blow out on the FI setups, even SOME NA setups need an upgrade
if you feel you need to do it. do it ..if not your probably fine....mase is right your probably fine
Old Feb 15, 2004 | 01:56 PM
J.R.'s Avatar
Default Re: At what point do you upgrade spark? (pornstarSR)
bump
Old Feb 15, 2004 | 03:13 PM
Bulldogg83's Avatar
Default Re: At what point do you upgrade spark? (J.R.)
for those who have upgraded their ignition......have you guys kept stock plugs and just added for example the MSD 6a or 6al with blaster coil?
Old Feb 15, 2004 | 03:48 PM
Blown90hatcH's Avatar
Default Re: At what point do you upgrade spark? (Bulldogg83)
I made 505 with just a blaster coil and some 9 heat range plugs.
JDM_VTI_Hatch
Dec 19, 2011 10:42 AM
92HB_HB
Apr 15, 2004 12:50 PM
BLKCRX
Jan 15, 2003 07:51 PM
SIK IN DA HED
Aug 13, 2002 02:43 PM
