help me identify this turbo
Old Feb 11, 2004 | 05:38 PM
Civic1.6VTEC's Avatar
Default help me identify this turbo
i know it's a Garret / Airesearch
Old Feb 11, 2004 | 05:40 PM
beepy's Avatar
Default Re: help me identify this turbo (Civic1.6VTEC)
Well, it's a T25. From what, not sure. But I think it's this one:
Which is a regular, non DSM T25.
ahobbs's Avatar
HELLO,GOOD MORNIN'
looks like a straight. t3
Old Feb 11, 2004 | 05:42 PM
legendboy's Avatar
Default Re: help me identify this turbo (HybridcivicLS-T)
looks like its off an old saab or volvo judging from the downpipe thingy. Not worth paying anything for imo
Old Feb 11, 2004 | 05:49 PM
Default Re: help me identify this turbo (legendboy)
minimal shaft play, and blades spin freely.
reaction360's Avatar
yeah looks like a straight T3 like he said. probably has a .42/.48 ars on it, check to see if there are any numbers on it.
Old Feb 11, 2004 | 05:55 PM
MikeMAN's Avatar
Default Re: help me identify this turbo (reaction360)
looks identical to my .48a/r saab t3
mike
Old Feb 11, 2004 | 06:08 PM
b18b1hmtlove's Avatar
its not a .42/.48 because the .42/.48 has a swingarm thinger and this one has an elbow.
I wouldnt be surprised if it was a T25 like said above
But im 95% sure that turbo is not a T3 .42/.48
Old Feb 11, 2004 | 06:20 PM
MikeMAN's Avatar
Default Re: (b18b1hmtlove)
co<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by b18b1hmtlove &raquo;</TD></TR><TR><TD CLASS="quote">its not a .42/.48 because the .42/.48 has a swingarm thinger and this one has an elbow.
But im 95% sure that turbo is not a T3 .42/.48</TD></TR></TABLE>
the turbo is NOT a t25..
i had the SAME one on my last b16 turbo setup
mike
Old Feb 11, 2004 | 06:33 PM
regime's Avatar
Default Re: (MikeMAN)
thats a 2JZ..... NO ****
Old Feb 11, 2004 | 06:40 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MikeMAN &raquo;</TD></TR><TR><TD CLASS="quote">co
mike</TD></TR></TABLE>
I dont think you are correct. ive never ever seen a .42/.48 with that type of elbow/internal gate.
.42/.48 T3's have turbine sides looking like this
Old Feb 11, 2004 | 06:45 PM
Default Re: (regime)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by regime &raquo;</TD></TR><TR><TD CLASS="quote">thats a 2JZ..... NO **** </TD></TR></TABLE>
wtf? damn F&F.
Old Feb 11, 2004 | 06:54 PM
Bailhatch's Avatar
measuring the flange could be usefull. A T3 flanged turbine lnlet measures about 1 3/4" X 2 5/16". It looks like one to me. look inside the turbine inlet and kind of scrape the sides to see if there is an A/R stamp that is covered by rust. The compressor cover A/R should be stamped inside the outlet.
If it's a T3 that is in good shape then definatly listen to ledgendboy. I buy lots of shitty T3s. Your far better off with the H-T junkyard ****, the DSM T25. Pay more get less. yay T25 cheap T3
Old Feb 11, 2004 | 07:29 PM
MikeMAN's Avatar
.42/.48 T3's have turbine sides looking like this </TD></TR></TABLE>
you may very well be correct, the thing that is confusing me is the wastegate on the original posted turbo looks like a t3 wastegate and not like the conventional t25 wastegate..however the fins look like a t25.
thanks for the pic,
mike
Old Feb 11, 2004 | 07:40 PM
it's a .42 and .46 or .48 not sure
Modified by Civic1.6VTEC at 11:54 PM 2/11/2004
Old Feb 11, 2004 | 07:58 PM
kinda looks like this http://cgi.ebay.com/ebaymotors...47029
except the one i posted is .42 or .46 or .48
Old Feb 11, 2004 | 08:07 PM
Dee's Avatar
Dee
The best way to shutup the guesstimators is look for cast markings and measure the blades. What is stamped inside of the exhaust housing inlet? What is stamped inside of the compressor housing outlet?
There ARE many types of swing valve exhaust housings floating around so it is easy to make assumptions when very little info is provided.
It looks like an AiResearch To4B or T3 to me but I am just guesstimating like everybody else.
Old Feb 11, 2004 | 08:15 PM
Default Re: help me identify this turbo (Dee)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Dee &raquo;</TD></TR><TR><TD CLASS="quote">The best way to shutup the guesstimators is look for cast markings and measure the blades. What is stamped inside of the exhaust housing inlet? What is stamped inside of the compressor housing outlet?
in the coldwheel it says .42, on the manifold it says .46 or .48, can't really read it.
Old Feb 11, 2004 | 08:20 PM
HXMan's Avatar
Whoa...it sure is a wierd looking engine! No wonder it can handle so much power stock block!!!
Old Feb 11, 2004 | 08:36 PM
legendboy's Avatar
Default Re: (HXMan)
lots of old turbos don't have much shaft play and spin freely, doesn't mean its not blown. That turbo is probably close to 20 years old
Old Feb 11, 2004 | 08:48 PM
Dee's Avatar
Dee
Default Re: (legendboy)
If you checked the stamps and found .42/.48 then you most definitely have a straight T3.
Old Feb 11, 2004 | 09:19 PM
Signal Auto's Avatar
Default Re: (Dee)
Its 100% a diesel turbo, T3.
Whiteintegra
Sep 29, 2006 08:20 AM
Demented
Apr 15, 2005 06:35 AM
pro547
Mar 20, 2005 03:30 PM
Taikonaut
Dec 2, 2003 01:40 PM
NoClassic
Sep 30, 2003 03:36 PM
