Turbo?
Old Feb 12, 2004 | 07:40 AM
Spoold_R's Avatar
New User
Default Turbo?
Hey guys i got my turbo from full race today its the t3/t67 with the stage 5 wheel. It seems as if the oil inlet and outlet is reversed? When i position the turbo with the turbine upwards as if i was mounting it a square-type whole is on the top, and on the underside is a threaded whole? Is it upside down?
Old Feb 12, 2004 | 07:45 AM
b18bturbo's Avatar
Default Re: Turbo? (RiTiCuLe)
all you have to do is clock the turbo in which ever direction you want. Its not that hard to do. Loosen the plate bolts and rotate till which way you want then retigten everything back up
Old Feb 12, 2004 | 07:57 AM
Spoold_R's Avatar
New User
Default Re: Turbo? (b18bturbo)
does that go for both sides, turbine and compressor?
Old Feb 12, 2004 | 08:05 AM
b18bturbo's Avatar
yes that is correct.
Old Feb 12, 2004 | 08:14 AM
Spoold_R's Avatar
New User
is there a touque spec to retighten the bolts?
AaronJ
Jan 4, 2007 02:27 PM
b18-c-rx
May 18, 2005 11:25 PM
yangtech
Oct 24, 2004 10:27 AM
TurboB18C1
May 18, 2004 09:13 PM
youngkow
Jan 3, 2003 12:03 PM
