b16a or b18b
Old Feb 11, 2004 | 01:06 PM
R.'s Avatar
R.
Default b16a or b18b
what would be a better platform? both cost the same.
im hoping for 300-350whp with a sc34... keeping the block stock. which engine would be better, and why?
Old Feb 11, 2004 | 01:08 PM
B18bEK's Avatar
prolly not gonna make much over 300 with the sc34 on a stock block but either way, go with the b18b, much better motor if you're keeping it stock and will produce much better numbers.
oh ya, if you just do a search..this topic has been beaten to death
Old Feb 11, 2004 | 01:49 PM
TurboJesse
Guest
Posts: n/a
Default Re: (B18bEK)
For making that much on stock block i would go with a vtec motor, b16a if you can't afford a b18c1. Theres no reason you couldn't make those numbers with an sc34.
Old Feb 11, 2004 | 01:58 PM
-Trinitron-'s Avatar
Yeah, with an sc 34 I would go with the LS. The 34 has a .48 A/R turbine right? which is a little short for a b16's high revs. With a stock block on the LS I would shoot for 250-275 with the SC34.
Old Feb 11, 2004 | 02:53 PM
LilManSi's Avatar
Default Re: (-TRINiTRON-)
i think it comes with .48 or .63...
Old Feb 11, 2004 | 04:27 PM
ahobbs's Avatar
HELLO,GOOD MORNIN'
Default Re: (LilManSi)
For 300-350. it would be alot easier to make that with an sc34...61 would be better though.vtec motor would get you there evven though im not a fan of them.
Old Feb 11, 2004 | 04:28 PM
B18bEK's Avatar
well if you look at the 2 people who just had theirs tuned .. stock LS w/ sc34 they made between 270-300 @14-16psi. and one of them blew their motor 5 minutes after the dyno. i wouldn't say its the most efficient turbo for making 300hp on a stock motor. the LS will produce much better hp/tq numbers than a b16 - review some dyno's and compare numbers for yourself
Old Feb 11, 2004 | 04:30 PM
ahobbs's Avatar
HELLO,GOOD MORNIN'
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B18bEK &raquo;</TD></TR><TR><TD CLASS="quote">well if you look at the 2 people who just had theirs tuned .. stock LS w/ sc34 they made between 270-300 @14-16psi. and one of them blew their motor 5 minutes after the dyno. i wouldn't say its the most efficient turbo for making 300hp on a stock motor. the LS will produce much better hp/tq numbers than a b16 - review some dyno's and compare numbers for yourself </TD></TR></TABLE>
b16 will make better hp than an b18, but all around i like the b18 better becuase they come dime a dozen when you blow them up.
b18 will make tons more torque.
Old Feb 11, 2004 | 04:51 PM
aka010010
Guest
Posts: n/a
more displacement, more power?
Old Feb 11, 2004 | 05:02 PM
markaria's Avatar
Default Re: b16a or b18b (R.)
The b16 will have the capability of more hp, but most definitely not torque. Although I have never had stock b16 cams (I have a itr head/ctr cams on a b16 block), I absolutely love the powerband. I hit my peak tq at full boost (3800rpm and it stays flat all the way to 8200+). It really makes for a large rpm range in which the car just MOVES. In order to pass a car quickly, I can drop it @65 in fifth and not only pull away, but probably make somone next to me think I dropped it down a gear or two...
In my personal opinion I think a b18b is a less expensive proposition, and it has a bit different of a personality, and a lot more tq. Though in order for a b18a/b to make peak hp like the b16/b18c, it needs some more head work and the ability to rev higher/breath more on top.
Old Feb 11, 2004 | 05:21 PM
TurboJesse
Guest
Posts: n/a
Blowing the motor has nothing to do with the turbo, an sc34 is plenty effecient @ 300whp. I agree with you on the tq thing but not the hp, the b16 will produce better hp. I still think if your shooting for 350ish on stock engine the b16a is a better choice than a b18b (although it will lack tq)
Old Feb 11, 2004 | 05:25 PM
ahobbs's Avatar
HELLO,GOOD MORNIN'
Default Re: (Mpir3)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mpir3 &raquo;</TD></TR><TR><TD CLASS="quote">
I still think if your shooting for 350ish on stock engine the b16a is a better choice than a b18b (although it will lack tq)</TD></TR></TABLE>
Old Feb 11, 2004 | 06:15 PM
b18b1hmtlove's Avatar
alot of people throw off a horse power number but i think tq number is more important than the hp number. Basically i chose the B18b because i would rather have 275whp and 250tq than 300whp and 200 tq.
Old Feb 11, 2004 | 06:20 PM
B18bEK's Avatar
Default Re: (b18b1hmtlove)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by b18b1hmtlove &raquo;</TD></TR><TR><TD CLASS="quote">alot of people throw off a horse power number but i think tq number is more important than the hp number. Basically i chose the B18b because i would rather have 275whp and 250tq than 300whp and 200 tq.</TD></TR></TABLE>
exactly .. you will have a better hp/tq balance.
Old Feb 11, 2004 | 07:30 PM
R.'s Avatar
R.
Default Re:
keep it coming guys...
so far im leaning towards the b16 from what you all have said.
Old Feb 11, 2004 | 08:51 PM
mattcalica's Avatar
see, I am running a b16 turbo in my 91 integra, but when that block blows, if it blows, then i am just gonna swap on my LS bottom end...theres a lot more **** you can do with a vtec motor.
Old Feb 11, 2004 | 09:12 PM
RyanAutry's Avatar
Default Re: (Mpir3)
Old Feb 12, 2004 | 07:10 AM
ITSTOCK's Avatar
Default Re: (RyanAutry)
Go with the b18b. Youll make much better torque numbers withe the b18b, and if you blwo it in the future there easier to come by. Theres plenty of ppl on here making 275whp on stock block b18bs @9-10psi.
Old Feb 12, 2004 | 12:48 PM
silverEH2's Avatar
b18b if i had a choice.....i hate weak16a's
Old Feb 12, 2004 | 01:45 PM
TurboJesse
Guest
Posts: n/a
Default Re: (silverEH2)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by silverEH2 &raquo;</TD></TR><TR><TD CLASS="quote">
b18b if i had a choice.....i hate weak16a's</TD></TR></TABLE>
I hate weak b18b's...
silverEH2's Avatar
Default Re: (Mpir3)
I hate weak b18b's...</TD></TR></TABLE>
LOL, if u only knew
Old Feb 12, 2004 | 01:47 PM
TurboJesse
Guest
Posts: n/a
LOL, if u only knew</TD></TR></TABLE>
your right i don't know
Old Feb 12, 2004 | 01:56 PM
silverEH2's Avatar
Default Re: (Mpir3)
your right i don't know </TD></TR></TABLE>
i could sit here and argue about this all day, but there is no reason. you like what you like. i like what i like. end of story
Old Feb 12, 2004 | 01:58 PM
nortel's Avatar
Default Re: (Mpir3)
hater
Old Feb 12, 2004 | 02:04 PM
TurboJesse
Guest
Posts: n/a
Default Re: (nortel)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nortel &raquo;</TD></TR><TR><TD CLASS="quote">
hater</TD></TR></TABLE>
exactly I would never own a b18b, their valve covers make me wanna puke....so ugly
