oil leaks ..help???
Old Feb 14, 2004 | 10:44 AM
r1lorenzini's Avatar
Default oil leaks ..help???
ok rant he stock 93 si last night with new grddy tdo4 kit and intercooler... 2 problems ..oil pan is leaking real bad on the rear side. tightened the bolts down really good, what lbs should they be at and the turbo is leaking out of the middle back section right below where the oil feed is? is my clamp on the oil feed section to loose i tightened it down hell off.
Old Feb 14, 2004 | 11:18 AM
twkdCD595's Avatar
Default Re: oil leaks ..help??? (r1lorenzini)
if you torqued down the pan already unevenly its probably slightly warped or the pan seal is bad someplace (not very common, they hold up well and I always reuse them).
you should take a pic of the turbo feed and return for us, and it would probably be a bunch of help.
Old Feb 14, 2004 | 11:21 AM
Flamenco-T's Avatar
are you using a hose clamp for the oil feed line ? if so, I would check the clamp itself, it may have seized up from overtightening.
Get a stainless steel teflon based line, better peace of mind than hose clamp. If your clamp gave out, oil will squirts out of the line leaving your motor and turbo straving for oil
stan
Old Feb 14, 2004 | 01:08 PM
its more like a metal clamp not a hose clamp that when loosened lets me move where the oilr return is .. like instead of coming straight down i can turn it a little to comout like 45 degree. what is the procedure for installing the oil pan gasket. i mena bolt tourque and pattern? can i reuse the new one i just put in or is it now shot since it is leaking really bad?
Old Feb 14, 2004 | 01:58 PM
1.8t's Avatar
Default Re: (r1lorenzini)
Make sure you apply a good bead of RTV sealant when putting on the oil pan. DO NOT BREAK THE BEAD at any point on the gasket. It will more than likely leak anywhere where the bead has a gap.
Old Feb 14, 2004 | 05:04 PM
damn i didnt use any rtv?!?!?!?!?!
MalcolmV8
Dec 5, 2011 05:29 PM
jprelude92
Aug 30, 2008 07:12 AM
btech
Jun 16, 2007 07:17 PM
UsaTLinh
Jun 2, 2004 10:58 PM
torr
Apr 14, 2004 07:48 AM
