Retorquing ARP studs on a D16a6
Old Feb 15, 2004 | 02:00 PM
ComputerJLT's Avatar
Default Retorquing ARP studs on a D16a6
I've put about 30 miles on my motor since i swapped the headgasket and installed the studs on this thing.
We tourqued them then double checked them; but im wondering if I need to retourque these things any time soon as they stretch?
Anyone have any input?
Old Feb 15, 2004 | 02:17 PM
danl's Avatar
Banned
Default Re: Retorquing ARP studs on a D16a6 (ComputerJLT)
The purpose of following the ARP instructions is to stretch the studs a predetermined amount without having to use a strain gauge as a professional assemblier would. They are not to stretch over time.
However, the cylider head will settle on the HG and block with heat cycles. I usually retorque them after 10 full heat cycles. A heat cycle is warming up a motor that has been sitting for more than 5 hours.
Old Feb 15, 2004 | 02:20 PM
Default Re: Retorquing ARP studs on a D16a6 (danl)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by danl &raquo;</TD></TR><TR><TD CLASS="quote">The purpose of following the ARP instructions is to stretch the studs a predetermined amount without having to use a strain gauge as a professional assemblier would. They are not to stretch over time.
However, the cylider head will settle on the HG and block with heat cycles. I usually retorque them after 10 full heat cycles. A heat cycle is warming up a motor that has been sitting for more than 5 hours.</TD></TR></TABLE>
thanks!
I followed the instructions to the T!! I am/was deathly afraid I'd **** this headgasket up. I put on one before this and reused the head bolts (bad idea) and it blew in less than a week; even with no boost
then we checked for warpage, cleaned it up real good, and bought some studs and a new gasket
Old Feb 15, 2004 | 02:21 PM
gritsak's Avatar
when most people go in to re-torque they usually dont budge, at least from my experience. but even with that said i dont think its a bad idea, at least worth doing it for the piece of mind
Old Feb 15, 2004 | 02:32 PM
Suprdave's Avatar
Default Re: Retorquing ARP studs on a D16a6 (gritsak)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by gritsak &raquo;</TD></TR><TR><TD CLASS="quote">when most people go in to re-torque they usually dont budge</TD></TR></TABLE>
Exactly...
Old Feb 15, 2004 | 03:03 PM
Nextelbuddy's Avatar
Default Re: Retorquing ARP studs on a D16a6 (Suprdave)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Suprdave &raquo;</TD></TR><TR><TD CLASS="quote">
Exactly...</TD></TR></TABLE>
so basically you are saying that if you have properly torqued ARP or AEBS headstuds in teh proper sequence that you do not need to retorque them?
i want ot know because i just finished putting my motor back together and was curious if i am going to have to tear apart my head again just to retorque them...
Old Feb 15, 2004 | 05:53 PM
Suprdave's Avatar
Default Re: Retorquing ARP studs on a D16a6 (nextelbuddy)
Basically...I think they key is making sure the Stud is seated well.
Everytime I've tried to re-torque them, they don't budge.
Old Feb 15, 2004 | 06:10 PM
Tad's Avatar
Tad
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nextelbuddy &raquo;</TD></TR><TR><TD CLASS="quote">
i want ot know because i just finished putting my motor back together and was curious if i am going to have to tear apart my head again just to retorque them...</TD></TR></TABLE>
it shouldnt be any problem to retorque them,
I dont think you should have to tear apart your head or anything,
just take the valve cover off
at least thats how it is on dseries.. maybe bseries has some part of the head that blocks the bolts, requiring some dissasembly to torque them??
fill me in
Old Feb 15, 2004 | 06:13 PM
DaX's Avatar
DaX
Loved
Community Favorite
VTEC B series heads have the head studs located underneath the camshaft. You must remove the cams to get to the studs.
Old Feb 15, 2004 | 07:07 PM
Tad's Avatar
Tad
Default Re: (DaX)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DaX &raquo;</TD></TR><TR><TD CLASS="quote">VTEC B series heads have the head studs located underneath the camshaft. You must remove the cams to get to the studs.</TD></TR></TABLE>
ooooh..
that suckz
Old Feb 16, 2004 | 07:59 AM
Default Re: (Tad)
yea so you se why i would be very happy if i dot have to tear apart the ead just to retorque somethign after 1000 miles if they dont need it...
Old Feb 16, 2004 | 09:30 AM
danl's Avatar
Banned
Default Re: (nextelbuddy)
I've never had the studs budge either, but i ALWAYS retorque them
Its really gay of honda to hide the heabolts. They usually do such a nice job with things like that. Their is no excuse either, because my DOHC 4g63 can be retorqued with the cams in place.
Old Feb 16, 2004 | 09:40 AM
5thgencivic's Avatar
Default Re: (danl)
I need to retorque mine. Are they supposed to be loosened then torqued down or just check them to see if they are still torqued?
Old Feb 16, 2004 | 09:44 AM
Farmer Brown's Avatar
Default Re: (5thgencivic)
No dont ever losen them if your not planing on taking the head off.
ilikejesus
Apr 3, 2007 07:04 PM
vtec-gorilla
Dec 1, 2006 05:46 PM
turbotime
Nov 12, 2005 02:06 PM
eg6cusco10pt
10
Sep 23, 2004 05:39 AM
