hack vs retarding timing
Old Feb 14, 2004 | 03:23 AM
infra's Avatar
Default hack vs retarding timing
i´ve spent my whole morning trying to find a good answer of what to do with the timing when running the hack but couldnt come up with any good answers.
so now i ask here instead... im running stock b16a2 with drag gen3 and the hack.
what should i do with my timing.. i dont wanna run a msd box because im gonna get AEM EMS as soon as the cash is there, but until then.
is it safe with retarding the timing like 4 degrees? i use ngks 7-n11 sparks.
i dont wanna loose all my hp without boost either.
btw we have 98octane fuel in sweden.
Old Feb 14, 2004 | 03:49 AM
rjardy's Avatar
Default Re: hack vs retarding timing (infra)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by infra &raquo;</TD></TR><TR><TD CLASS="quote">i´ve spent my whole morning trying to find a good answer of what to do with the timing when running the hack but couldnt come up with any good answers.
btw we have 98octane fuel in sweden.</TD></TR></TABLE>
no its not safe, but its "safer" than nothing.
Rob
Old Feb 14, 2004 | 04:23 AM
infra's Avatar
how much is recommended to retard ?
Old Feb 14, 2004 | 06:02 AM
rjardy's Avatar
Default Re: (infra)
id do 2 to start.
Rob
Old Feb 14, 2004 | 08:17 AM
Bailhatch's Avatar
Default Re: (rjardy)
I had to pull 3 at 8psi to keep it from pinging. I keep the boost down because I don't want to retard it any more. I 'm pretty sure I could be more agressive with the boost or timing if I had my 2.5' exhaust done. stock must be creating some heat problems and maybe some reversion
Old Feb 14, 2004 | 09:36 AM
twkdCD595's Avatar
Default Re: (Bailhatch)
I also asked the same question in this thread this morning early early you may have missed it https://honda-tech.com/zerothread?id=766999
seems to be 3 is a good place to start.
Old Feb 14, 2004 | 11:28 AM
R@mon's Avatar
Default Re: (twkdCD595)
on 98 octane you should be ok with only 2 degrees pulled out, but i would go over 10 psi with out retarding more...
Old Feb 14, 2004 | 11:30 AM
Mase's Avatar
how much boost are you planning on running?
Old Feb 14, 2004 | 11:32 AM
twkdCD595's Avatar
Default Re: (93h22a4)
damn, missed the 98 octane part somewhat... I would love that kind of octance normally at the pump here. I was thinking about with 93, premium here.
dbang003
Apr 30, 2004 12:41 PM
X2BOARD
10
Apr 8, 2004 05:18 AM
boost fed ls
Aug 11, 2003 08:26 AM
asianspeed
Aug 8, 2003 05:05 AM
88ZCRX
Jul 20, 2003 07:19 AM
