did i miss anything?
this will be my first motor build and im trying to make a list of parts before i start buying stuff and endup getting the wrong stuff.
here is my list, if you can add any info or options please help me out.
thanks
Turbo Parts
SST Turbo Mani
24x12x3.5 Intercooler
550 RC Injectors or 440 DSM Injectors
Downpipe Flange
2.5 Charge Pipes
3.0 Downpipe
3.0 Thermal Exhaust
Oil Return Lines
Misc Hoses
Turbo Timer
Boost Gauge
Oil PSI Gauge
Oil Temp Gauge
Water Temp Gauge
Air/Fuel Gauge
Hondata 200b w/ Boost option
Blow Off Valve
Exhaust Mani Gasket
T3/t04e Garrett 57 Trim w/.63 A/R Turbine
38mm Tial Wastegate .5 bar Spring
Endyn Catch Can/PCV Bypass
Z10 PCV Hole Plug
Engine Parts
9.0:1 CP Pistons
Eagle Rods
ACL Rod Bearings
ACL Main Bearings
Cosmetic Headgasket
Hondata Intake Mani Gasket
Skunk2 Valve Springs
Skunk2 TI Retainers
1mm oversized valves
Valve Seals
Edlebrock Intake Mani
Edlebrock TB
Oil Pan
ARP Head Bolts
ARP Main Bolts
Block Sleeves (brand?)
Misc Wires
Water Pump
Timing Belt
Toda Cam Gears
Oil Pump
Misc Bolts/Screws
Ignition Cap/Rotor/Coil/6a/wires/plugs
Fuel Pressure Reg, FPR
Fuel Rail
255 Fuel Pump
Lightweight Flywheel
Pressure Plate
Clutch Plate
Throwout Bearing
Thrust Washer
ARP Flywheel Bolts
Oil Pan Gasket
Timing Belt Tensor
Cam Seals x2
Cluster Gauge Holder
Rear Motor Mount
ES Motor Mount Inserts
thanks
Turbo Parts
SST Turbo Mani
Downpipe Flange
2.5 Charge Pipes
3.0 Downpipe
3.0 Thermal Exhaust
Oil Return Lines
Misc Hoses
Turbo Timer
Boost Gauge
Oil PSI Gauge
Oil Temp Gauge
Water Temp Gauge
Air/Fuel Gauge
Blow Off Valve
Exhaust Mani Gasket
Z10 PCV Hole Plug
Engine Parts
9.0:1 CP Pistons
Eagle Rods
ACL Rod Bearings
ACL Main Bearings
Cosmetic Headgasket
Skunk2 TI Retainers
Valve Seals
Edlebrock TB
Oil Pan
ARP Head Bolts
ARP Main Bolts
Misc Wires
Water Pump
Timing Belt
Toda Cam Gears
Oil Pump
Misc Bolts/Screws
Fuel Rail
255 Fuel Pump
Pressure Plate
Clutch Plate
Throwout Bearing
Thrust Washer
ARP Flywheel Bolts
Oil Pan Gasket
Timing Belt Tensor
Cam Seals x2
Rear Motor Mount
Re: did i miss anything? (oMekoneDC2)
ur probably planning on running really high boost considering all the components u listed......taking that into account..u will probably be better off going with the 550 Rc's. If u run those..u will need a resistor box....aswell..goodluck
Re: did i miss anything? (Chillinit)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Chillinit »</TD></TR><TR><TD CLASS="quote">ur probably planning on running really high boost considering all the components u listed......taking that into account..u will probably be better off going with the 550 Rc's. If u run those..u will need a resistor box....aswell..goodluck</TD></TR></TABLE>
thanks, ya im going for 10 daily and 18 at the drags. what resistor will i need for the 550 RCs?
Re: (T-RO)
or some 10watt resistors from radio shack will work. Why do you only want to run 10psi on the street? With a setup like that you could definately run more safely.
Re: (genop)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by genop »</TD></TR><TR><TD CLASS="quote">or some 10watt resistors from radio shack will work. Why do you only want to run 10psi on the street? With a setup like that you could definately run more safely.</TD></TR></TABLE>
its a daily driver and i need it to last some what.
MagnaniEG6
10-07-2010 03:21 PM
x still jaded x
09-07-2010 04:05 PM
