please help!! turbo injector problems..
Old Feb 14, 2004 | 01:18 PM
asnboi817's Avatar
Default please help!! turbo injector problems..
I'm running the afc hack with -36 to -38 across the board. I can't figure out why my car won't start. When i look on the AFC screen, it says that my PRS is up and my car isn't even running. I have DSM 450cc injectors and i installed that on right. I have obd1 injector clips and i can't figure out y it doesn't work. I see gas all over the intake mani when i try to start it and now it won't even choke, i twist the key and it's like starting the car w/o pushing down the clutch. I do have a resistor box but it's the kinda round one, not the blocky ones that i see online in the "how to's". I hope i didn't mess up my car. I tried trial and error with the wiring and everytime the car wouldn't even get close to starting. Something else i noticed was that today the afc resets everytime i take the key out of the car. this is driving me nuts!! i want to test drive my car w/ boost sometimes soon....please help.
Old Feb 14, 2004 | 02:02 PM
twkdCD595's Avatar
Default Re: please help!! turbo injector problems.. (asnboi817)
sounds like afc wiring problems...
check your afc wiring and all connections... did you use crimp on connections or did ya solder them?
Old Feb 14, 2004 | 02:44 PM
Cruiser G's Avatar
Default Re: please help!! turbo injector problems.. (twkdCD595)
Definetly wiring, check all your connections, including injectors and resistor box.
Old Feb 14, 2004 | 03:12 PM
boosted_dc2's Avatar
Default Re: please help!! turbo injector problems.. (Cruiser G)
also try to start it with the stock injectors, and stock wiring to confirm that its not your injector wiring as well. make sure you follow the directions to the afc good and ground the brown and black wires correctly.
Landon
MBlake55
13
Aug 18, 2007 08:41 AM
asnboi817
Feb 16, 2004 11:52 PM
Slimer89
May 1, 2003 10:06 AM
