Action 2MD clutch users
Old Feb 15, 2004 | 11:59 AM
Wo-Nelly's Avatar
Default Action 2MD clutch users
How do you guys/gals like the clutch? Is it streetable? I'm in the market for a new clutch but I can't afford a twin disc so I'm looking at other options. It's a 6 puck un-spung disc, correct? How does it drive in stop and go traffic? And how long have you had it, does it wear down real fast or does it have some decent life to it?
Old Feb 15, 2004 | 07:27 PM
Wo-Nelly's Avatar
Default Re: Action 2MD clutch users (Wo-Nelly)
up for some answers pls
Old Feb 15, 2004 | 07:32 PM
Bnjmn's Avatar
I have a step above the 2MD (not a twin disk) and it is very streetable, pedal effort is fine. It is a little on/off but with some practice it should be fine.
Ben
Old Feb 15, 2004 | 07:37 PM
SiRkid's Avatar
yeah. its fine.
takes some getting used to but you should be ok.
it is basically on off(you can slip it but not much).
Old Feb 15, 2004 | 08:02 PM
MADEINIRAQ's Avatar
Default Re: Action 2MD clutch users (SiRkid)
i like mine.. using a used CM pressure plate.. but the pedal feel is like stock
kinda on or off.. but i daily drive it with no problems. don't mind it at all
Old Feb 16, 2004 | 03:28 AM
Wo-Nelly's Avatar
Default Re: Action 2MD clutch users (madeiniraq)
I thought a sprung 6 puck would be more streetable then the non-sprung 6 puck but I was told the 2md would be better for me. Is that right?
Old Feb 16, 2004 | 03:42 AM
HYBRID_H@TCH's Avatar
sprung clutchs tend to "chatter" more due to the springs loading and unloading..I have a 2MD and drive with it like its stock.
Old Feb 16, 2004 | 05:29 AM
BROOD's Avatar
I like the 2MD in my case, but I would not enjoy it as much if I dealt with heavy traffic frequently. For holding extra driveline power it does it's job well.
I do suggest if you are street driving it alot to use an aftermarket flywheel instead of an OEM flywheel. Repeated slipping of this puck/unsprung clutch will put alot of heat into the flywheel. OEM flywheels get weaker as the are abused in this way. I'd rather be safe and run a SFI cert fylwheel right from the start.
Old Feb 16, 2004 | 06:10 AM
metal-x's Avatar
Default Re: Action 2MD clutch users (BROOD)
I like mines as well
but I still have that anoying grinding sound when goin into 1s't gear
Old Feb 16, 2004 | 06:37 AM
swlabhot's Avatar
Default Re: Action 2MD clutch users (metal-x)
I run the 2MD. The pedal is pretty stiff compared to oem but you get use to it pretty quickly. As its pretty much an on/off clutch, driving in traffic is not very pleasant due to the unsprung nature and as you can't really slip it as you can with a normal clutch. A lot of people including myself experience that screeching noise when you try to slip it in situations where it can't be helped (ie, when your in slow moving traffic, parking lot etc...). If you spend a lot of time in traffic I wouldn't go for the MD. On the flip side, it will handle quite some torque you can throw at it, so if you're boosted and do some drag racing etc...then its all good.
chunky
16
Feb 25, 2007 09:40 AM
meltSolid
Dec 5, 2002 10:52 AM
bluemex
Sep 1, 2002 09:04 PM
ALF
Oct 27, 2001 11:20 AM
