Misfire CEL 74 Help!!!!
Old May 25, 2005 | 09:38 AM
b00sted4dr's Avatar
Default Misfire CEL 74 Help!!!!
Ok im getting a misfire cel 74. My car drive and ifles normal. I have no idea what is causing this cel. I have changed distributor cap and switched to another working dirstirbutor. I have changed new spark plugs and new spark plug wires.
I swapped around the injectors and still i get this CEL!!! When im using the obd1 ecu, i get no cel. Its only when i run the obd2 ecu.
Oh yeah, all this happened after i was boosted and when back to stock. When i went back to stock, i used my old obd2 p72 and thats when i got the cel.
Someone help me out, i want to resolve this issue so i can boost again and get tuned..
Old May 25, 2005 | 03:53 PM
b00sted4dr's Avatar
Default Re: Misfire CEL 74 Help!!!! (b00sted4dr)
bump.
Old May 26, 2005 | 06:36 AM
200cs's Avatar
my itr had this problem before boost. It was the factory coil. I replaced it with a Jacobs set-up and it works fine. Good luck
Old May 26, 2005 | 07:15 AM
b00sted4dr's Avatar
Default Re: Misfire CEL 74 Help!!!! (200cs)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 200cs &raquo;</TD></TR><TR><TD CLASS="quote">my itr had this problem before boost. It was the factory coil. I replaced it with a Jacobs set-up and it works fine. Good luck </TD></TR></TABLE>
Thanks for the response
Old Jun 2, 2005 | 08:12 PM
b00sted4dr's Avatar
TTT
BLacK FirE
Jul 13, 2006 01:56 PM
b00sted4dr
Jun 26, 2005 06:39 AM
b00sted4dr
Jun 23, 2005 09:17 PM
spooned out
Mar 21, 2005 04:28 PM
conesmasher
Oct 19, 2004 03:26 PM
