egt in middle of manifold?
Old May 29, 2005 | 06:27 AM
95boostedteg's Avatar
Default egt in middle of manifold?
I have bought a sfp manifold and its already tapped for egt. What i noticed is that at idle its around 700 degree and normal cruising it jumps to a little under 1400 degress. I know the best place for the egt is the third number, but will it throw off the readings if its in the middle?
Old May 29, 2005 | 04:06 PM
underpressure02's Avatar
Default Re: egt in middle of manifold? (95boostedteg)
no it will not throw off the readings. Most people say to put it at the number 3 cylinder b/c that runs the hottest. You are now just getting more of a general reading
Old May 29, 2005 | 05:01 PM
ildknyli's Avatar
Default Re: egt in middle of manifold? (underpressure02)
So runner #3 runs hotter...So itll be better to hook the EGT to it?
Old May 29, 2005 | 05:29 PM
integlspwr2k's Avatar
Default Re: egt in middle of manifold? (ildknyli)
i put my egt sensor on the waste gate elbow because i really only need to know egt when im in boost. If im in vaccumm, you dont need to worry.
Ash J. Williams
Apr 2, 2013 07:37 AM
NuclearB18B
Jul 7, 2005 11:28 AM
platinum00
Dec 23, 2004 08:21 AM
evoeone
Feb 11, 2003 05:40 PM
b18cTurbo
Mar 29, 2002 08:03 PM
