waste gate question
Old May 28, 2005 | 12:53 PM
slo_crx's Avatar
Default waste gate question
ok well i finally got my car boosted im running the same waste gate i did on my other setup which is a tial 38mm ,.. on my old setup i couldnt go over like 5 pounds because the waste gate makes a wooshing noise and boost climbs very choppy .... now i changed everything on the setup except the waste gate and its doing the same thing ..(choppy climb and woosh) so im guessing its the waste gate that is going wrong here.. my question is ..is my waste gate fucked up or do i just need a bigger spring to make it work correctly ... im guessing the spring i have in there is a 4.5 psi one and that is why i cant go over that with out it ******* up .. ohh yeah and i have a greddy profec B for my boost controller
Old May 29, 2005 | 03:55 AM
slo_crx's Avatar
Default Re: waste gate question (slo_crx)
up
Old May 29, 2005 | 10:53 AM
slo_crx's Avatar
wtf come on people i know you guys know these kinda things
Old May 30, 2005 | 05:46 AM
slo_crx's Avatar
Old May 30, 2005 | 05:56 AM
NJIN BUILDR's Avatar
You either have your boost controller plumbed wrong or your controller or waste gate is damaged.Sounds like your just running off the spring.You should be able to hold more than ten pounds with a controller and a 4.5# spring.
Glenn
Old May 30, 2005 | 08:53 AM
slo_crx's Avatar
Default Re: waste gate question (NJIN BUILDR)
well is it possible i have the controller hooked up wrong ?either way .. the controller hooks up to the top of the waste gate does it need to tee off into a vacuum source or just connect to its self .... right now i have everything running to a vacume soruce incleding the profec.. is this right?>
Old May 30, 2005 | 08:57 AM
wantboost's Avatar
Who is Mr Robot?
the controller has to be hooked into both ports of the wg... theres your problem
Old May 30, 2005 | 09:03 AM
Mr. Vapor's Avatar
Default Re: waste gate question (wantboost)
yes, your boost controller needs to have two vac lines going to the WG. one to the intake manifold (vac source) and the other (the one on top of the WG) should be going to the controller solonoid to tell the boost controller when to open and close the WG.
sounds like a simple fix.
Old May 30, 2005 | 09:07 AM
wantboost's Avatar
Who is Mr Robot?
Default Re: waste gate question (Mr. Vapor)
VTEC+Mini
Aug 5, 2012 02:28 AM
gsr x civic
Jun 21, 2007 04:01 AM
94sol
Nov 22, 2006 11:00 AM
freeplay
Sep 4, 2003 06:38 PM
Dancing is Forbidden
Feb 16, 2003 08:42 AM
