Greddy 18g controlling flapper
Old May 27, 2005 | 09:11 AM
Drkaccrd's Avatar
Default Greddy 18g controlling flapper
Alright I've the searches and found nothing related to this. Can I put a manual boost controller to manage the internal wasgate from over boosting?
Old May 27, 2005 | 09:28 AM
Drkaccrd's Avatar
Default Re: Greddy 18g controlling flapper (Drkaccrd)
bump please
Old May 27, 2005 | 09:59 AM
Drkaccrd's Avatar
Bump again
Old May 27, 2005 | 10:28 AM
Turbo E's Avatar
a MBC will only allow you to increase the boost till your motor blows up (overboost). you cant lower the boost.
Old May 27, 2005 | 10:43 AM
Drkaccrd's Avatar
Default Re: (Turbo E)
Will it keep the boost from spiking?
Old May 27, 2005 | 10:56 AM
dustin's Avatar
Default Re: (Drkaccrd)
No. Boost controllers only let you run MORE boost. You can never run less boost (than the WG spring rating) with a boost controller.
Old May 27, 2005 | 11:08 AM
Drkaccrd's Avatar
Default Re: (dustin)
It wont turn it down but could it help regulate it at a steady boost level?
Old May 27, 2005 | 11:11 AM
dustin's Avatar
It won't be any steadier than it was before the boost controller.
Old May 27, 2005 | 11:14 AM
Drkaccrd's Avatar
Damn it. So porting the flapper hole is the only choice huh?
Old May 27, 2005 | 12:56 PM
Integra21's Avatar
pretty much and larger flapper if you want
Old May 27, 2005 | 01:43 PM
ITSME4G63's Avatar
flapper http://www.slowboyracing.com/more.php?id=108&
and porting the turbo a lil
Old May 28, 2005 | 05:46 AM
99blusi's Avatar
Default Re: (ITSME4G63)
IIRC the 34mm flapper won't fit in there. The greddy uses a small flapper...
Old Jun 2, 2005 | 12:53 PM
Drkaccrd's Avatar
Default Re: (99blusi)
Damn I guess there is no other way around it huh? I was hoping there was. Oh well. But I can control how high it goes with either upgrading to an external wastegate or a an mbc tuned with hondata?
Old Jun 4, 2005 | 08:16 PM
PA MATT's Avatar
wouldnt an electronic boost controller control this because of the solenoid?
Old Jun 6, 2005 | 06:54 AM
Drkaccrd's Avatar
Default Re: (PA MATT)
Damn good question.........the thing is I've always heard that MBC's are more dependable.... i dunno..........
Old Jun 6, 2005 | 06:59 AM
TheShodan's Avatar
Moderator
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Drkaccrd &raquo;</TD></TR><TR><TD CLASS="quote">It wont turn it down but could it help regulate it at a steady boost level? </TD></TR></TABLE>
On Electronic boost controllers with a stepper motor solenoid, it is possible to relieve some of the spiking that is appearent, but that must be set precisely to do it. Blitz, Greddy, and Apex'i all have boost controllers w/ solenoids to assist in controlling spike.
The best way is to port the WG hole itself, by about 1-2mm, and it should also assist in the correction.
Old Jun 6, 2005 | 08:41 AM
beepy's Avatar
Default Re: (TheShodan)
if all else fails, go old school and install a bypass valve. I saw a thread on here where a guy made a bypass valve from a radiator cap.
Old Jun 6, 2005 | 08:59 AM
Black R's Avatar
25 Year Member
I think I've read somewhere that you can put a softer spring in the internal wastegate for the greddy and then run the boost off an electronic boost controller more precisely.....
Old Jun 7, 2005 | 05:55 AM
Drkaccrd's Avatar
Default Re: (beepy)
This bypass valve you speak of is for not allowing boost spike?
Old Jun 7, 2005 | 08:08 AM
beepy's Avatar
Basically you install a valve - much like a BOV - that opens when a certain pressure is on it. It's an old-school trick, but it works. If the thing opens at 10 PSI, the charge pipes will not see more than 10 PSI. Of course, such things play havoc on MAF cars.
Old Jun 7, 2005 | 08:44 AM
Drkaccrd's Avatar
Default Re: (beepy)
Tell me how please. I've done searches and found nothing worth trying.
Old Jun 7, 2005 | 01:40 PM
Jcup315's Avatar
I am internally wastegated and I was overboosting for a while until I adjusted the wastegate actuator arm and it lowered it by 2psi
Old Jun 7, 2005 | 09:28 PM
Black R's Avatar
25 Year Member
https://honda-tech.com/zerothread?id=1269291
I believe this is what you are looking for.....
IN VTEC
Feb 13, 2008 07:07 AM
DMax013
Apr 25, 2005 11:05 AM
incognitoracerr
Apr 23, 2003 06:52 AM
skilzz
Oct 24, 2002 03:37 AM
