Help w/ Motorla 2.5 bar Map sensor
Old May 28, 2005 | 01:26 PM
used2baracer's Avatar
Default Help w/ Motorla 2.5 bar Map sensor
having problems on hooking up a motorola 2.5 bar map... I have signal to pin 1, ground to pin 2 and power to pin 3. Car runs like no map w/ uberdata (won't turn on) and won't rev w/ chrome (but idles fine). Checked with voltmeter and I have .4v w/ car @ 20in vac and .17v @ 0vac (engine off). I would think that there would be more voltage at 0vac then 20in vac. Any help appreciated...
Old May 28, 2005 | 01:31 PM
tony1's Avatar
Default Re: Help w/ Motorla 2.5 bar Map sensor (used2baracer)
you sure the sensor is an absolute pressure sensor? If it's not, it'll only read right with pressure over atmospheric. If it's guage pressure, then that's only 0 and up. Where did you get the sensor from?
Old May 28, 2005 | 01:34 PM
Default Re: Help w/ Motorla 2.5 bar Map sensor (tony1)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tony1 &raquo;</TD></TR><TR><TD CLASS="quote">you sure the sensor is an absolute pressure sensor? If it's not, it'll only read right with pressure over atmospheric. If it's guage pressure, then that's only 0 and up. Where did you get the sensor from?</TD></TR></TABLE>
pretty sure its the right sensor... got from digikey w/ part number from pgmfi wiki : #MPX4250AP
Old May 28, 2005 | 01:37 PM
tony1's Avatar
hmm, i've never used those so I can't really help any more. Why not just go with a gm 3 bar map?
Old May 28, 2005 | 01:56 PM
2.5bar recommended by a lot over 3bar quality/tuning wise and also their only $15-20
Old May 28, 2005 | 03:30 PM
hooked up a spare 2bar gm map sensor and it worked perfect... wtf? anybody... i don't think it's the sensor because I have 2 of them and they both do the same...
Old May 28, 2005 | 07:52 PM
xenocron's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote &raquo;</TD></TR><TR><TD CLASS="quote">Connect Pin 1 (Vout) to the ‘Reference’ signal in your stock MAP sensor wiring.
Connect Pin 2 (GND) to the Ground wire in your stock MAP sensor wiring.
Connect Pin 3 (Vs) to the 5v signal wire in your stock MAP sensor wiring.
Looks like you have it hooked up correctly...nothing else is hooked up? I notice in Crome when I did mine up it was noticeably leaner at first startup and needed to be tuned a little richer even with the same MAP scalars.
You sure you are using PIN 1 (with the notch in it) correctly?
Old May 28, 2005 | 11:44 PM
Default Re: Help w/ Motorla 2.5 bar Map sensor (xenocron)
yeah... i had to blip it to even get it to rev up... so i finally got pissed after four hours and just went with a 2 bar i had. Does anyone know if it's possible to burn these things out??? I hooked it up wrong at first, so maybe thats it...
Old May 29, 2005 | 12:26 PM
USDM 4G VTEC's Avatar
check pgmfi
i already posted there
Old May 29, 2005 | 12:57 PM
nfn15037's Avatar
Default Re: (USDM 4G VTEC)
You probably didn't use pin 1. If you look at it what appears to be the back side, pin one is on the left and has a notch in it. FWIW if you aren't planning on running more than 22 PSI, the Motorola 2.5 bar is the way to go!
Old May 29, 2005 | 01:04 PM
Default Re: (nfn15037)
Yeah, it was pin one... I damn near have the manufacturer/data sheet memorized... it said pin one was the one with the notch. Really weird cus i talked to a lot of people and they all said theirs was hooked up like mines. I pluged a gm2bar in and it worked right away. I have a 1bar wastegate also, so I guess the GM Map sensor will do...
Has anyone ever blown one of these out hooking it up wrong, or got a defective one???
Old May 29, 2005 | 01:16 PM
nfn15037's Avatar
Default Re: (used2baracer)
I've used probably 20 of them and never had a bad one...maybe you got the 1st?
Old May 29, 2005 | 04:38 PM
ComputerJLT's Avatar
i got mine for free from an un-nameable source
i haven't even tried wiring it up yet.
I'm going to build a case for it so i can mount it in the engine bay and not have to worry about it breaking. I'll also graft a stock honda plug on it somehow.
Old May 29, 2005 | 05:49 PM
93turbo16's Avatar
I am using a 4-pin header for my plug, and then using pins from an old wiring harness to plug it into the map plug.
Old May 29, 2005 | 06:21 PM
nfn15037's Avatar
Default Re: (93turbo16)
I cut up an old MAP sensor for the plug, and soldered a shrinkwrapped a short pigtail to the MAP sensor. Then I encased it in hot glue and put it in a tiny plastic enclosure and mounted it to eh firewall behind the IM so the vac line stays as short as possible.
Old May 30, 2005 | 11:59 AM
I just soldered the wires right to it with plans of heatshrinking over...
Old May 30, 2005 | 01:28 PM
non-VTEC's Avatar
where can i get one of these 2.5 bar sensors besides digikey?
anyone willing to sell one?
Old May 30, 2005 | 01:55 PM
DENCIO's Avatar
Default Re: (non-VTEC)
here ya go..
http://www.arrownac.com/aws/pg_webc?s=P
Old May 30, 2005 | 07:19 PM
Default Re: (DENCIO)
be careful which part number you get... i checked arrow too but they didn't have the ones w/. the vacuum port...
Old May 31, 2005 | 10:08 AM
xenocron's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by non-VTEC &raquo;</TD></TR><TR><TD CLASS="quote">where can i get one of these 2.5 bar sensors besides digikey?
anyone willing to sell one? </TD></TR></TABLE>
I have a few in possession right now. I have been toying with selling them on my site but they are so readily available at Digikey...I unno. Seems easy to use them for local guys only.
if you need one, let me know.
integlspwr2k
Nov 11, 2007 06:08 PM
-JSpecEk*9-
22
Jun 8, 2006 02:26 PM
abmerop18
May 28, 2006 07:45 PM
weiRtech
Feb 26, 2006 12:39 PM
Civic89
Jun 17, 2002 01:26 PM
