Favorite soch turbo vid??
Favorite sohc turbo vid??
Re: Favorite sohc turbo vid?? (1boostedcivic)
Re: Favorite sohc turbo vid?? (tgreaves)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tgreaves »</TD></TR><TR><TD CLASS="quote">Here is mine.. And its me also..
http://www.prosportcompact.com....mpeg</TD></TR></TABLE>
hmm my real player wont play this one. and u usually host some good vids. damn wish i could see this one.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 1boostedcivic »</TD></TR><TR><TD CLASS="quote">
hmm my real player wont play this one. and u usually host some good vids. damn wish i could see this one. </TD></TR></TABLE>
Strange.. Try downloading the vid and play if from your local drive..
Strange.. Try downloading the vid and play if from your local drive..</TD></TR></TABLE>
wow saw ur vid. that crx moves like an animal. thats a bone stock sohc non-vtec???
Civic Tsi
60mb, totally worth it.
More Info
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by "Civic Tsi" »</TD></TR><TR><TD CLASS="quote"># Block:
* D16Z6
* Stock Sleeves Bored .020 Over
* Welded NewformZ Blockguard
* ARP Head Studs
* CP 9:1 Pistons
* Eagle Rods
* Stock Crank
# Head:
* Ported D16Z6 Head
* Manley Stainless Steel Valves
* Zex Valves Springs
* SDP Titanium Valves Retainers
* SDP Custom Camshaft
* Skunk2 Cam Gear
* SDP Intake Manifold
* Hondata HeatShield Intake Gasket
* Stock Head Gasket
# Electronics:
* MSD 6AL
* MSD Blaster 2 coil
* MSD 2 Step Rev Limiter
* Greddy Turbo Timer
* Greddy Profec B Boost Controller
* P28 ECU running Uberdata
* GM 3 Bar Map Sensor
# Induction:
* Mitsubishi TD05-20G Turbo (660cfm)
* Front Mount Intercooler 30"x11"x3.5"
* HKS Super Sequential Blow Off Valve
* Tial 38mm External WG with 15psi Spring
# Fuel:
* Precision 680cc Injectors
* Walbro 255L Fuel Pump
* Holley Fuel Pressure Regulator
* Stock Fuel Line
* Stock Fuel Rail
# Gauges
* FJO Wideband with Gauge Display
* Autometer Oil Temp
* Autometer Oil Pressure
* Autometer Water Temp
* Autometer Vacuum/Boost
* Autometer EGT
# Exhaust:
* SDP Turbo Manifold
* SDP 3" Stainless Steel Downpipe
* SDP 3" Stainless Steel Exhaust
* Vibrant 3" Stainless Steel Muffler
# Stopping:
* ITR Front Calipers
* Stock Rear Calipers
* Brembo 11.2" Front Disc
* Brembo 8" Rear Disc
* Hawk HP+ Pads
* Braided Stainless Steel Brake Lines
* 15/16 Brake Booster
* ITR Master Cylinder
* ITR Brake Repartition Valve
# Stiffness:
* Koni Yellow Shocks
* H&R Race Springs
* Protane Total Kit Bushings
* Protane Motor Mounts Kit
* JimFab Traction Bars
* Neuspeed Front Upper Tie Bar
* Fast Front Lower Tie Bar
* Neuspeed Rear Lower Tie Bar
* Fast Rear Upper Tie Bar
# Driveline:
* 11lbs Flywheel
* ClutchMaster Stage 4 Clutch
* 98 Si Tranny with 4th and 5th Gears from a 91 Si Tranny
* Quaife LSD
* Stock Axles
* M&H 22 x 8 x 15 Slicks
* Toyo RA-1 Street Tires
Car weight about 2350lbs with me in racing form.
310whp @ 15psi, mustang dyno. Best time to date 11.6
More Info
* D16Z6
* ARP Head Studs
* CP 9:1 Pistons
* Eagle Rods
* Stock Crank
# Head:
* Ported D16Z6 Head
* Skunk2 Cam Gear
* Stock Head Gasket
# Electronics:
* MSD 6AL
# Induction:
# Fuel:
* Stock Fuel Line
* Stock Fuel Rail
# Gauges
* Autometer EGT
# Exhaust:
# Stopping:
* Hawk HP+ Pads
# Stiffness:
* H&R Race Springs
# Driveline:
* 11lbs Flywheel
* Quaife LSD
* Stock Axles
wow saw ur vid. that crx moves like an animal. thats a bone stock sohc non-vtec???</TD></TR></TABLE>
Yep, bone stock D16Y7 non-vtec engine with a Garrett/Airesearch T3 and a crx hf manifold..
nice <TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tgreaves »</TD></TR><TR><TD CLASS="quote">
Yep, bone stock D16Y7 non-vtec engine with a Garrett/Airesearch T3 and a crx hf manifold..</TD></TR></TABLE>
http://www.slammdsol.com/tony1.wmv</TD></TR></TABLE>
Damn, I'm lovin that thing like whoa...
Re: Favorite sohc turbo vid?? (Thurman Merman)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Thurman Merman »</TD></TR><TR><TD CLASS="quote">Favorite all around sohc-t video is the good ol' purple coupe </TD></TR></TABLE>
Me too.
Good editing, music, filming, it was a cool vid. I haven't seen it in a while though.
Me too.
Re: Favorite sohc turbo vid?? (EJ1 wilcox)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EJ1 wilcox »</TD></TR><TR><TD CLASS="quote">
Me too.
Good editing, music, filming, it was a cool vid. I haven't seen it in a while though. </TD></TR></TABLE>
here ya go brotha
http://www.we-todd-did-racing....DE%3D
Me too.
here ya go brotha
purple car has very nice editing and music.
Here is my video...not the best, but its a sohc-T
Re: (Unsivil_audio)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Unsivil_audio »</TD></TR><TR><TD CLASS="quote">Civic Tsi
More Info
Link still doesn't work ...I wanna see I wanna see
More Info
Re: (adseguy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by adseguy »</TD></TR><TR><TD CLASS="quote">
Link still doesn't work ...I wanna see I wanna see </TD></TR></TABLE>
It wont woks till June 1st. I had to disable all the vids. I have a 200G bandwidth per month and it got busted in 7 days in May. First time this happen
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Thurman Merman »</TD></TR><TR><TD CLASS="quote">here ya go brotha
http://www.we-todd-did-racing....DE%3D</TD></TR></TABLE>
purple car video is sweet!
http://videos.streetfire.net/P...t=top
not sure if the if this civic is sohc or dohc by the sound but kicks ***,
also turbod16.com video wasn't that bad either
https://umdrive.memphis.edu/kc...e.wmv
Re: Favorite sohc turbo vid?? (Cee_mon)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Cee_mon »</TD></TR><TR><TD CLASS="quote">purple car has very nice editing and music.
man this car sounds nice. what kind of numbers are u putting up? is it stock?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 1boostedcivic »</TD></TR><TR><TD CLASS="quote">man this car sounds nice. what kind of numbers are u putting up? is it stock?</TD></TR></TABLE>
Its a stock d16z6 running about 7psi in video. Awaiting plx-300 (in mail) and going up to 9-10.
